potential issue with starter when HOT? |
JF914 |
Apr 10 2010, 10:37 PM
Newbie Group: Members Posts: 20 Joined: 9-September 09 From: Boulder Member No.: 10,786 Region Association: Rocky Mountains |
Has anyone had a problem with the starter after a long drive? Driving on a long trip. After second gas stop, all it does is spin. Does not engage and turn over engine?
Will this cure itself when cool? Is that what folks mean by the "dreaded hot start starter issue". Never happened before, but then again, have never driven over 150 miles at a clip. |
Tom_T |
Apr 10 2010, 11:28 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Has anyone had a problem with the starter after a long drive? Driving on a long trip. After second gas stop, all it does is spin. Does not engage and turn over engine? Will this cure itself when cool? Is that what folks mean by the "dreaded hot start starter issue". Never happened before, but then again, have never driven over 150 miles at a clip. Let me add that I agree with Andy that the usual dreaded is the click - no joy problem, usually due to heat expansion freezing the motor & solenoid. However, this sounds like the related dread - where the solenoid is to hot, expands & won't engage the gear & the starter spins. Yup - that's it! (IMG:style_emoticons/default/biggrin.gif) The starter & solenoid get hot, & either the solenoid can't push the starter in to engage &/or the starter won't turn at all. It's also an intermittent problem on other Porsches & VW's, in part due to the heat of the engine. It usually indicates that it's time for a new starter &/or solenoid soon. Yes, it usually cures itself when the engine cools down. If not or if in a hurry, have someone try starting it with the key, while you're under the back end with a hammer or something to tap the starter as they're engaging the key to the start position. That will usually break it loose. I had a similar problem last summer on a trip in our 88 VW Westy, & my son & I double teamed to do that to get it started, then replaced with a rebuilt started at our destination - GoWesty for some other work anyway! (IMG:style_emoticons/default/biggrin.gif) Some folks buy the thermal blanket for the starter to insulate it from the engine heat. I've seen them sold at PP & probably others too. I hope that didn't happen to Dan? (IMG:style_emoticons/default/sad.gif) |
JF914 |
Apr 11 2010, 07:59 AM
Has anyone had a problem with the starter after a long drive? Driving on a long trip. After second gas stop, all it does is spin. Does not engage and turn over engine? Will this cure itself when cool? Is that what folks mean by the "dreaded hot start starter issue". Never happened before, but then again, have never driven over 150 miles at a clip. Let me add that I agree with Andy that the usual dreaded is the click - no joy problem, usually due to heat expansion freezing the motor & solenoid. However, this sounds like the related dread - where the solenoid is to hot, expands & won't engage the gear & the starter spins. Yup - that's it! (IMG:style_emoticons/default/biggrin.gif) The starter & solenoid get hot, & either the solenoid can't push the starter in to engage &/or the starter won't turn at all. It's also an intermittent problem on other Porsches & VW's, in part due to the heat of the engine. It usually indicates that it's time for a new starter &/or solenoid soon. Yes, it usually cures itself when the engine cools down. If not or if in a hurry, have someone try starting it with the key, while you're under the back end with a hammer or something to tap the starter as they're engaging the key to the start position. That will usually break it loose. I had a similar problem last summer on a trip in our 88 VW Westy, & my son & I double teamed to do that to get it started, then replaced with a rebuilt started at our destination - GoWesty for some other work anyway! (IMG:style_emoticons/default/biggrin.gif) Some folks buy the thermal blanket for the starter to insulate it from the engine heat. I've seen them sold at PP & probably others too. I hope that didn't happen to Dan? (IMG:style_emoticons/default/sad.gif) Called Triple A and was able to jump start the car. Said that is was more of a "humm" noise when I spoke to him. AAA tech thought that the battery terminals may have needed cleaning, but sounded like he was on his way. Will see about the starter this AM. I hope it was a fluke versus the "dreaded starter issue", but was hard to get details when calling in from the road. Will report back later, but this will be good to have diagnosed by a professional when at the final destination. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:50 PM |
