QUOTE(JF914 @ Apr 10 2010, 09:37 PM)
Has anyone had a problem with the starter after a long drive? Driving on a long trip. After second gas stop, all it does is spin. Does not engage and turn over engine?
Will this cure itself when cool?
Is that what folks mean by the "dreaded hot start starter issue". Never happened before, but then again, have never driven over 150 miles at a clip.
Let me add that I agree with Andy that the usual dreaded is the click - no joy problem, usually due to heat expansion freezing the motor & solenoid. However, this sounds like the related dread - where the solenoid is to hot, expands & won't engage the gear & the starter spins.
Yup - that's it!
The starter & solenoid get hot, & either the solenoid can't push the starter in to engage &/or the starter won't turn at all. It's also an intermittent problem on other Porsches & VW's, in part due to the heat of the engine.
It usually indicates that it's time for a new starter &/or solenoid soon.
Yes, it usually cures itself when the engine cools down. If not or if in a hurry, have someone try starting it with the key, while you're under the back end with a hammer or something to tap the starter as they're engaging the key to the start position. That will usually break it loose.
I had a similar problem last summer on a trip in our 88 VW Westy, & my son & I double teamed to do that to get it started, then replaced with a rebuilt started at our destination - GoWesty for some other work anyway!
Some folks buy the thermal blanket for the starter to insulate it from the engine heat. I've seen them sold at PP & probably others too.
I hope that didn't happen to Dan?
