towing a teener, backwards? |
bare 1 |
Apr 10 2010, 04:30 PM
Member Group: Members Posts: 122 Joined: 27-October 04 From: Apache Junction viaWhidbey Is. Member No.: 3,019 Region Association: None |
On a two wheel dolly. due to circumstances beyond my control I gotta drag my rig from north of Seattle to Phoenix Anybody towed this way?? She got no motor or tranny in her and my wife does'nt like the idea of a full size trailer behind her Grand Cherokee. (she's doing the driving , I have larger responsibilities) I'm a lttle concerned with the front end waltzing all over the place. Any experience with this??
bare 1 |
Apr 12 2010, 11:15 AM
Have to look at those axles again. I just replaced the rear wheel bearings and can't remember how all that goes together right now I kinda thought with the axles out nothing much is holding the wheel on . flat towing sounds goood and would be the least work for the wife's Grand. Buuut How do you hook it up??? What's this hitch your're talking about and where do I get one??? Not much up there to hook to
ArtechnikA |
Apr 12 2010, 11:28 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Have to look at those axles again. I just replaced the rear wheel bearings and can't remember how all that goes together right now I kinda thought with the axles out nothing much is holding the wheel on . That is correct. This is why you _separate the stub axle from the outboard CV's_ and re-install them. Actually you must do this any time you put weight on the rear bearings... With the stub axles re-bolted to the hubs, you're good to go. I've actually seen a 914 tow bar - once - a long time ago. it was custom-manufactured and bolted to lugs that extended through the front bumper. I'm not sure how it was attached to the tub on the other side of the bumper... The front A-Arm mounts would be another good place to attach - if you could find a tow bar. I've seen them advertised from time to time by private parties but have never actually materialized. They might be out there but they are not common. Don't forget that if you have _any_ wheels on the ground, the vehicle must be registered. Many have got away with it but just be aware of the situation. A flat-towed vehicle should have brake, tail, and turn signal lights. You might get away with that, too, in the day time, but one couldn't recommend it... |
hsus2k |
Apr 12 2010, 01:03 PM
Newbie Group: Members Posts: 16 Joined: 6-April 10 From: Suwanee, GA Member No.: 11,567 Region Association: South East States |
Just purched this Tow bar Bracket for my 914 few weeks ago. Still haven't mount it yet, but it suppose to mount to the two front A-arm bracket (cover) mount area.
Make sure the area is not rusted! and hooks up to your Super Beetle "Y"-shaped towbar, or they have another one for the Reese towbar. 914 Tow Bar Bracket Since mine it's a roller right now, I can tow it to the paint shop without worrying about my transmission. But do I really need to disconnect the hub to the Axel when transmission is in place? Even though if I lock it in nutural? I used to tow my Bugs & Super beetle with a tow bar, and all I have to do is have the key in the steering wheel to allow it to turn and have the grear in Nutural, and I have tow many times on the highway long distances (and without any instances)? (IMG:style_emoticons/default/confused24.gif) |
ArtechnikA |
Apr 12 2010, 01:08 PM
Lo-Fi Version | Time is now: 12th June 2024 - 07:49 AM |
