> Is this a good looking undercarriage?, Opinions please!!
rwilner
post Apr 12 2010, 05:35 PM
No Ghosts in the Machine
I'm considering buying this car. It leaks a few drops of oil when it sits overnight, the heat has been removed but he has all the parts -- i'll put it back on.
Scroll down for all pics.
Please opine... (IMG:style_emoticons/default/popcorn[1].gif)
jasons
post Apr 12 2010, 05:51 PM
Jackstand Extraordinaire
I see red flags. The clutch cable is "bailing wired" to the trans. That could leave you stranded. I don't think the location of the fuel pump is right. Shouldn't it be on the lower firewall? Rust (or shotty repair) above the heater tube, where the oil cooler lines are run. The suspension ear looks welded.
rwilner
post Apr 12 2010, 05:58 PM
QUOTE(jasons @ Apr 12 2010, 07:51 PM) *
Yes -- suspension ears (both) were welded by Racer Chris, probably the most solid part of the car.
As for the clutch cable, I'm not familiar with what it *should* look like...but I do know I don't like being stranded!!
post Apr 12 2010, 06:02 PM
Resident German
QUOTE(rwilner @ Apr 12 2010, 04:58 PM) *
It's moved out of the way because of the headers. It's still VERY close to the headers so heat is an issue ...
If you had stock heat exchangers on that car, the clutch cable would be a straight shot forward. Currently, it's bend upwards with bail-wire to clear the headers ...
(IMG:style_emoticons/default/shades.gif) Andy
rwilner   Is this a good looking undercarriage?   Apr 12 2010, 05:35 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:36 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:37 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:38 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:40 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:42 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:43 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:44 PM
scotty b   Well you've got the mechanical parts coverd in...   Apr 12 2010, 05:41 PM
Tom_T   Rob, That looks like a possible rust problem up b...   Apr 12 2010, 05:47 PM
rwilner   Rich, That looks like a possible rust problem up...   Apr 12 2010, 05:50 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 05:56 PM
jasons   I see red flags. The clutch cable is "bailin...   Apr 12 2010, 05:51 PM
rwilner   I see red flags. The clutch cable is "baili...   Apr 12 2010, 05:58 PM
jasons   Yes -- suspension ears (both) were welded by Race...   Apr 12 2010, 06:01 PM
SirAndy   As for the clutch cable, I'm not familiar wit...   Apr 12 2010, 06:02 PM
SirAndy   The hell hole is rusted, your fuel pump mount has ...   Apr 12 2010, 05:54 PM
rwilner   The hell hole is rusted, I can't tell that ...   Apr 12 2010, 06:10 PM
dlee6204   The car is going to need some work to make it righ...   Apr 12 2010, 05:57 PM
rwilner   How do you expect to add heat with headers and t...   Apr 12 2010, 06:00 PM
rwilner   RE: Is this a good looking undercarriage?   Apr 12 2010, 06:01 PM
rwilner   This looks like leaking brake fluid but seller say...   Apr 12 2010, 06:01 PM
rwilner   Fancy Bushings!!   Apr 12 2010, 06:03 PM
6freak   This looks like leaking brake fluid but seller sa...   Apr 13 2010, 08:10 AM
McMark   The number of 'oddities' would make me ner...   Apr 12 2010, 06:13 PM
rwilner   if price is right, it doesn't look horrible. ...   Apr 12 2010, 06:20 PM
McMark   The right price depends on too many things. I...   Apr 12 2010, 06:28 PM
bandjoey   Take the inspection covers off of the tunnel by th...   Apr 12 2010, 08:46 PM
jaxdream   Check with the owner to see if he / she will allow...   Apr 13 2010, 08:02 AM
rwilner   Check with the owner to see if he / she will allo...   Apr 13 2010, 08:18 AM
rwilner   a few more pics   Apr 13 2010, 08:20 AM
Racer Chris   Pictures of the floor inside the car don't tel...   Apr 13 2010, 08:35 AM
jaxdream   I agree with Chris about the floor and tar boards ...   Apr 13 2010, 09:02 AM
dangrouche   For $5k, too much. It is clean. It looks to...   Apr 13 2010, 09:48 AM
rwilner   For $5k, too much. It is clean. It looks t...   Apr 13 2010, 10:29 AM
SirAndy   Dan, I am curious -- why do you say tranny synchr...   Apr 13 2010, 11:50 AM
rwilner   Dan, I am curious -- why do you say tranny synch...   Apr 13 2010, 12:33 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:19 PM
