Can I remove the 2 bolts on the forward control arm? |
Porsche Rescue |
Apr 12 2010, 05:23 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am about to install a David Lee flat tow bracket on my car. It is to be towed behind my motorhome on occasion.
The car is on the ground, wheels on. I pulled the allen head bolt that holds the front cap off and began to loosen the two bolts that hold the bushing carrier to the body. Then I thought I better do some research, having never removed a front torsion bar or control arm. Any reason not to simply remove the bolts and attach the bracket with the new longer bolts? |
Porsche Rescue |
Apr 12 2010, 07:12 PM
Thanks. I took them off and one side did drift a bit, easily realigned. Bracket holes will not line up properly however. Appears I will need to enlarge the bracket holes a bit. At least I hope that will allow it to bolt up.
Edit: Looks like my problem won't be solved with larger holes. Bracket cut-outs won't straddle both control arm carriers. I almost seems as though the bracket is about 3/8" too short. |
Lo-Fi Version | Time is now: 12th June 2024 - 12:13 AM |
