Transmission removal, How to |
wilchek |
Apr 12 2010, 07:47 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
So my transmission has been having issues. So out it must come. All went awesome not a single stuck bolt or rust issue. A true miracle for a 914 (IMG:style_emoticons/default/piratenanner.gif) . However, the previous owner decided to relocate the battery to a box in the trunk. The box is welded in to the upper right corner and for the most part is out of the way in the trunk. However, it extends into the transmission area. So I start to pull the tranny and yep the housing hit the battery box after pulling the trans I cleared everything except the two bottom studs. I decided to use another nut and jam one so I can remove the stud. Worked great and transmission came out without a problem
brant |
Apr 12 2010, 08:14 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
moving weight rearward is not good for balance.
sure a 30lb battery may not be noticeable on the street but why change anything to "hurt" handling? |
Lo-Fi Version | Time is now: 12th June 2024 - 06:33 PM |
