Can I remove the 2 bolts on the forward control arm? |
Porsche Rescue |
Apr 12 2010, 05:23 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am about to install a David Lee flat tow bracket on my car. It is to be towed behind my motorhome on occasion.
The car is on the ground, wheels on. I pulled the allen head bolt that holds the front cap off and began to loosen the two bolts that hold the bushing carrier to the body. Then I thought I better do some research, having never removed a front torsion bar or control arm. Any reason not to simply remove the bolts and attach the bracket with the new longer bolts? |
jcd914 |
Apr 12 2010, 11:25 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Pictures would help.
I have not experience with the bracket you are installing just some questions for you. Does the bracket go on the bottom of the A-arm mounts or between the mounts and the body? Is there a top and bottom to the bracket that might make a difference? Do the holes need to move forward or backward or to the side? Jim |
Lo-Fi Version | Time is now: 12th June 2024 - 12:00 AM |
