towing a teener, backwards? |
bare 1 |
Apr 10 2010, 04:30 PM
Member Group: Members Posts: 122 Joined: 27-October 04 From: Apache Junction viaWhidbey Is. Member No.: 3,019 Region Association: None |
On a two wheel dolly. due to circumstances beyond my control I gotta drag my rig from north of Seattle to Phoenix Anybody towed this way?? She got no motor or tranny in her and my wife does'nt like the idea of a full size trailer behind her Grand Cherokee. (she's doing the driving , I have larger responsibilities) I'm a lttle concerned with the front end waltzing all over the place. Any experience with this??
6freak |
Apr 12 2010, 02:58 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
NOT SUPPOSE TO HAUL A CAR ON A DOLLY BACKWARDS ...ITS INTENED TO BE DUEL POINT hitch ...at the hitch and at the steering rack .....if you strap the back of the car to it hows it gonna swivel ....its got 4 wheels on the ground...unless the DOLLY itself swivels at the hitch and were the car straps on....just say`nn ......JMO
ArtechnikA |
Apr 12 2010, 03:32 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
NOT SUPPOSE TO HAUL A CAR ON A DOLLY BACKWARDS ...ITS INTENED TO BE DUEL POINT hitch ...at the hitch and at the steering rack .....if you strap the back of the car to it hows it gonna swivel ....its got 4 wheels on the ground...unless the DOLLY itself swivels at the hitch and were the car straps on....just say`nn ......JMO what? |
6freak |
Apr 12 2010, 08:47 PM
NOT SUPPOSE TO HAUL A CAR ON A DOLLY BACKWARDS ...ITS INTENED TO BE DUEL POINT hitch ...at the hitch and at the steering rack .....if you strap the back of the car to it hows it gonna swivel ....its got 4 wheels on the ground...unless the DOLLY itself swivels at the hitch and were the car straps on....just say`nn ......JMO what? when you put the front wheels on the dolly ...you dont lock the front wheels,so the steering wheel turns freely as you go around a corner right ! if you put the back of the car on said dolly and lock the front wheels the dolly will skid around the corner ..dolly requires two pivot points its not a trailer ...hope that helps get my point across...IMO flat tow is the safest way for someone with no trailer expirience |
jcd914 |
Apr 13 2010, 01:08 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
NOT SUPPOSE TO HAUL A CAR ON A DOLLY BACKWARDS ...ITS INTENED TO BE DUEL POINT hitch ...at the hitch and at the steering rack .....if you strap the back of the car to it hows it gonna swivel ....its got 4 wheels on the ground...unless the DOLLY itself swivels at the hitch and were the car straps on....just say`nn ......JMO what? when you put the front wheels on the dolly ...you dont lock the front wheels,so the steering wheel turns freely as you go around a corner right ! if you put the back of the car on said dolly and lock the front wheels the dolly will skid around the corner ..dolly requires two pivot points its not a trailer ...hope that helps get my point across...IMO flat tow is the safest way for someone with no trailer expirience The front or rear wheels are strapped down to a platform on the tow dolly and the platform pivots so the wheels don't have to do anything except stay attached to the car. You can put a car backwards on a tow dolly, I have done it, towed a wrecked Audi from LA to Sacramento backwards on a tow dolly. It had been hit in the rear and the rear suspension was bent up so I could not put the front wheel on the dolly. With the front engine trans configuration of the Audi it was tail heavy towing that way but it worked out OK. I would flat tow it if you can come up with the tow bar and mounts. I have used a Ford Aerostar, Ford Explorer, Toyota pick-up and my RV to flat tow 914's and they all handled it well. I have had a 914 (and other cars) on a trailer behind both the Aerostar and Explorer and they did fine but I prefer the less overall weight of flat towing. Jim |
6freak |
Apr 13 2010, 08:04 AM
[quote name='jcd914' date='Apr 13 2010, 12:08 AM' post=...unless the DOLLY itself swivels at the hitch and were the car straps on....just say`nn ......JMO
when you put the front wheels on the dolly ...you dont lock the front wheels,so the steering wheel turns freely as you go around a corner right ! if you put the back of the car on said dolly and lock the front wheels the dolly will skid around the corner ..dolly requires two pivot points its not a trailer ...hope that helps get my point across...IMO flat tow is the safest way for someone with no trailer expirience [/quote] The front or rear wheels are strapped down to a platform on the tow dolly and the platform pivots so the wheels don't have to do anything except stay attached to the car. You can put a car backwards on a tow dolly, I have done it, towed a wrecked Audi from LA to Sacramento backwards on a tow dolly. It had been hit in the rear and the rear suspension was bent up so I could not put the front wheel on the dolly. With the front engine trans configuration of the Audi it was tail heavy towing that way but it worked out OK. I would flat tow it if you can come up with the tow bar and mounts. I have used a Ford Aerostar, Ford Explorer, Toyota pick-up and my RV to flat tow 914's and they all handled it well. I have had a 914 (and other cars) on a trailer behind both the Aerostar and Explorer and they did fine but I prefer the less overall weight of flat towing. Jim [/quote] so some dollys do pivot under the wheels ...I thought that they were all solid ... |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:14 PM |
