Transmission removal, How to |
wilchek |
Apr 12 2010, 07:47 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
So my transmission has been having issues. So out it must come. All went awesome not a single stuck bolt or rust issue. A true miracle for a 914 (IMG:style_emoticons/default/piratenanner.gif) . However, the previous owner decided to relocate the battery to a box in the trunk. The box is welded in to the upper right corner and for the most part is out of the way in the trunk. However, it extends into the transmission area. So I start to pull the tranny and yep the housing hit the battery box after pulling the trans I cleared everything except the two bottom studs. I decided to use another nut and jam one so I can remove the stud. Worked great and transmission came out without a problem
Joe Ricard |
Apr 13 2010, 06:23 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Use a PC680 battery and make the box at least 3" shorter.
Root_Werks |
Apr 13 2010, 08:30 AM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Use a PC680 battery and make the box at least 3" shorter. (IMG:style_emoticons/default/agree.gif) That's the next battery for my 914 very soon. The PC925 is way overkill for a stock 4cyl engine. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:33 PM |
