Once Again, Flared Rim Fitment 16x7's+8's, What offset? |
jmill |
Apr 12 2010, 11:08 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I have AA metal flares. I have 16x7's with 911 offset (...020.44 I think) for the front. I need 8's for the rear. Do I stick with the 911 offset or get the 944/951 offset?
Guys in the know, please step up and tell me what offset you're running (part # would be great) + spacer thickness if any for an 8" rim in the rear. Tire sizes would be great too. (IMG:style_emoticons/default/confused24.gif) We need an all you need to know about rims and tires thread. |
jmill |
Apr 13 2010, 08:46 AM
I have the 951 wheels both front and rear. Fronts are 16x7 with 225-50-16 tires Rears are 16x8 with 245-45-16 tires. I love the look on the rear. The fronts look too small in my opinion. I am kinda looking for a set of 951 16x8 rims for the front so I can run the same size tire all the way around. This should also help with my understeer problem. Clay, are you running any spacers with those rears? Is the part number for your rears the same as the second from the bottom on the chart? Thanks |
ClayPerrine |
Apr 13 2010, 09:49 AM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have the 951 wheels both front and rear. Fronts are 16x7 with 225-50-16 tires Rears are 16x8 with 245-45-16 tires. I love the look on the rear. The fronts look too small in my opinion. I am kinda looking for a set of 951 16x8 rims for the front so I can run the same size tire all the way around. This should also help with my understeer problem. Clay, are you running any spacers with those rears? Is the part number for your rears the same as the second from the bottom on the chart? Thanks Yes they are the same part number. No, I am not running any spacers. I have steel flares, and the tires don't hit. They are close, though. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:19 PM |
