What are people doing after driving in the rain... |
dank |
Apr 13 2010, 02:58 PM
DanielK Group: Members Posts: 25 Joined: 8-March 10 From: Mountain View, CA Member No.: 11,440 Region Association: None |
...in terms of preventive rust maintenance, etc.?
Found this on what people who water-wash their car do, so I assume it's the same type of stuff? http://www.914world.com/bbs2/index.php?showtopic=71280 air compressor to blow out water from any nooks and crannies, after making sure in particular to get (with a towel): - trunk gutters - bottom corners of the front trunk, since water travels from top corners to bottom. - inside edges of the window trim - the black plastic vent plugs in the door jams |
lotus_65 |
Apr 13 2010, 06:22 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
just make sure the drain holes are clear.
i'd check the turn signal housings unless you know the seals are perfect. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:54 PM |
