bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
Well,
Working on the 914 again, and was making room for an EMC so, I removed the backpad, and this is what I found. Well, I had seen the panel from the engine compartment, and knew it was there. So, here's the hole: ![]() And the cover, WTF? Farmer bob did this one? ![]() Ok. It works, and I am not the best craftsman, as I have done a couple of, eh, quick-fixes for a problem, which I fixed later. So, put it back? Rather not. Any ideas? -- brett BTW, the PO also put an access panel in for the starter. ![]() This will be used for the remote battery. I will clean up and make something for it. The battery cable is temporarily there... (just made a minor edit. I said timing, when I meant fan! Doh.) |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Many /6 guys cut a hole there so they can set the timing. The cover is a hack but an easy fix.
Starter hole on the other hand is a total hack. |
Lo-Fi Version | Time is now: 4th July 2025 - 05:18 PM |
