> Fan Belt access cover for six, Innovation or WTF?
bfrymire
post Apr 17 2010, 06:28 PM
Salsaholic
Well,
Working on the 914 again, and was making room for an EMC so, I removed the backpad, and this is what I found.
Well, I had seen the panel from the engine compartment, and knew it was there.
So, here's the hole:
And the cover, WTF? Farmer bob did this one?
Ok. It works, and I am not the best craftsman, as I have done a couple of, eh, quick-fixes for a problem, which I fixed later.
So, put it back? Rather not. Any ideas?
-- brett
BTW, the PO also put an access panel in for the starter.
This will be used for the remote battery. I will clean up and make something for it. The battery cable is temporarily there...
(just made a minor edit. I said timing, when I meant fan! Doh.)
tat2dphreak
post Apr 19 2010, 05:05 PM
stoya, stoya, stoya
as good as the idea sounds on paper, there would have to be some way to make sure it was closed up enough with a material comparable to the steel that was removed..
imo you'd have to make some sort of fire-gasket there too. and make sure it's air tight, so if there WAS a fire it couldn't get into the cabin.
pcar916
post Apr 19 2010, 06:37 PM
Is that a Lola?
QUOTE(tat2dphreak @ Apr 19 2010, 03:05 PM) *
That's a good idea. The steel internals of my edge mouldings (flame would have to get through two of them) will help for a while but the material that goes around the doors of our ovens will work better until there's a real NOMEX (or something like it) barrier.. That's easy and fast to fix. Cool
bfrymire   Fan Belt access cover for six   Apr 17 2010, 06:28 PM
Mark Henry   Many /6 guys cut a hole there so they can set the ...   Apr 17 2010, 06:43 PM
bfrymire   Many /6 guys cut a hole there so they can set the...   Apr 17 2010, 08:05 PM
GeorgeRud   I haven't cut the access hole in my firewall (...   Apr 17 2010, 07:15 PM
ClayPerrine   I haven't cut the access hole in my firewall ...   Apr 19 2010, 11:19 AM
SLITS   I haven't cut the access hole in my firewall ...   Apr 19 2010, 03:24 PM
Dr Evil   I put a nice hole in my firewall and made a nice d...   Apr 17 2010, 08:16 PM
jt914-6   Some pics of Pcar916's cover. I need to make o...   Apr 18 2010, 02:50 PM
rfuerst911sc   I cut a decent sized opening in my firewall for my...   Apr 18 2010, 03:08 PM
Root_Werks   I'm not for cutting holes in the firewall of a...   Apr 19 2010, 11:27 AM
pcar916   My access hole pictured above by JT9146 uses Dzus ...   Apr 19 2010, 11:46 AM
Root_Werks   There you go! That looks like something that ...   Apr 19 2010, 11:49 AM
pcar916   There you go! That looks like something that...   Apr 19 2010, 12:00 PM
tat2dphreak   as good as the idea sounds on paper, there would h...   Apr 19 2010, 05:05 PM
pcar916   imo you'd have to make some sort of fire-gask...   Apr 19 2010, 06:37 PM
rfuerst911sc   I really think you guys are over thinking this acc...   Apr 19 2010, 06:45 PM
Dave_Darling   Evidently the really tough part is actually notici...   Apr 19 2010, 07:55 PM
Mike Knox   Here's a shot of my access panel. I covered t...   Apr 19 2010, 08:45 PM
Mike Knox   Here's another view, this view is obviously fr...   Apr 19 2010, 08:54 PM
brant   I think I might have the lightest one (aluminum):   Apr 19 2010, 10:00 PM
brant   covering:   Apr 19 2010, 10:01 PM
bfrymire   covering: Ok. That one I really like. TIme t...   Apr 20 2010, 12:06 AM
Maltese Falcon   This cutout was made for the horizontal fan bi-tur...   Apr 20 2010, 06:35 AM
dennisc   Best way to change the belt on a 6 is take the rea...   Apr 20 2010, 07:36 AM
tat2dphreak   aluminum also has the lowest melting point...   Apr 20 2010, 09:04 AM
Dave_Darling   But it's fine for a race car. Why? Because y...   Apr 20 2010, 10:07 AM
Root_Werks   There is a pretty old thread somewhere about this....   Apr 20 2010, 10:28 AM
pcar916   Whatever you do don't spend more than a couple...   Apr 20 2010, 10:44 AM
- Lo-Fi Version Time is now: 4th July 2025 - 04:32 PM
