> Fan Belt access cover for six, Innovation or WTF?
bfrymire
post Apr 17 2010, 06:28 PM
Salsaholic
Well,
Working on the 914 again, and was making room for an EMC so, I removed the backpad, and this is what I found.
Well, I had seen the panel from the engine compartment, and knew it was there.
So, here's the hole:
And the cover, WTF? Farmer bob did this one?
Ok. It works, and I am not the best craftsman, as I have done a couple of, eh, quick-fixes for a problem, which I fixed later.
So, put it back? Rather not. Any ideas?
-- brett
BTW, the PO also put an access panel in for the starter.
This will be used for the remote battery. I will clean up and make something for it. The battery cable is temporarily there...
(just made a minor edit. I said timing, when I meant fan! Doh.)
Dave_Darling
post Apr 19 2010, 07:55 PM
914 Idiot
Evidently the really tough part is actually noticing the car is on fire! Since the "hot bits" are behind you, and when you're at speed they don't throw off enough smoke to be immediately obvious, you may be using up part of your 2-3 minutes without ever knowing it...
--DD
bfrymire   Fan Belt access cover for six   Apr 17 2010, 06:28 PM
Mark Henry   Many /6 guys cut a hole there so they can set the ...   Apr 17 2010, 06:43 PM
bfrymire   Many /6 guys cut a hole there so they can set the...   Apr 17 2010, 08:05 PM
GeorgeRud   I haven't cut the access hole in my firewall (...   Apr 17 2010, 07:15 PM
ClayPerrine   I haven't cut the access hole in my firewall ...   Apr 19 2010, 11:19 AM
SLITS   I haven't cut the access hole in my firewall ...   Apr 19 2010, 03:24 PM
Dr Evil   I put a nice hole in my firewall and made a nice d...   Apr 17 2010, 08:16 PM
jt914-6   Some pics of Pcar916's cover. I need to make o...   Apr 18 2010, 02:50 PM
rfuerst911sc   I cut a decent sized opening in my firewall for my...   Apr 18 2010, 03:08 PM
Root_Werks   I'm not for cutting holes in the firewall of a...   Apr 19 2010, 11:27 AM
pcar916   My access hole pictured above by JT9146 uses Dzus ...   Apr 19 2010, 11:46 AM
Root_Werks   There you go! That looks like something that ...   Apr 19 2010, 11:49 AM
pcar916   There you go! That looks like something that...   Apr 19 2010, 12:00 PM
tat2dphreak   as good as the idea sounds on paper, there would h...   Apr 19 2010, 05:05 PM
pcar916   imo you'd have to make some sort of fire-gask...   Apr 19 2010, 06:37 PM
rfuerst911sc   I really think you guys are over thinking this acc...   Apr 19 2010, 06:45 PM
Dave_Darling   Evidently the really tough part is actually notici...   Apr 19 2010, 07:55 PM
Mike Knox   Here's a shot of my access panel. I covered t...   Apr 19 2010, 08:45 PM
Mike Knox   Here's another view, this view is obviously fr...   Apr 19 2010, 08:54 PM
brant   I think I might have the lightest one (aluminum):   Apr 19 2010, 10:00 PM
brant   covering:   Apr 19 2010, 10:01 PM
bfrymire   covering: Ok. That one I really like. TIme t...   Apr 20 2010, 12:06 AM
Maltese Falcon   This cutout was made for the horizontal fan bi-tur...   Apr 20 2010, 06:35 AM
dennisc   Best way to change the belt on a 6 is take the rea...   Apr 20 2010, 07:36 AM
tat2dphreak   aluminum also has the lowest melting point...   Apr 20 2010, 09:04 AM
Dave_Darling   But it's fine for a race car. Why? Because y...   Apr 20 2010, 10:07 AM
Root_Werks   There is a pretty old thread somewhere about this....   Apr 20 2010, 10:28 AM
pcar916   Whatever you do don't spend more than a couple...   Apr 20 2010, 10:44 AM
- Lo-Fi Version Time is now: 4th July 2025 - 04:05 PM
