Mikey - whats the possibility of making these NLA rubber parts?, Who would want these? Speak Up! |
JeffBowlsby |
Apr 22 2010, 10:53 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Chassis harness snorkel tube
Attached image(s) |
McMark |
Apr 23 2010, 09:50 AM
I am IN for both. And I'll be a repeat customer on those for sure. Pretty much every snorkel out there is toast.
While a split snorkel would be neat and dead simple to install, the rear section of the harness is REALLY simple to pull. I'd also be more nervous of the split snorkel coming undone later. QUOTE I asked Mark about doing the "suction housing" gasket for the alternator recently since its NLA. Which one is that? The 'ring' between the alternator body and the engine tin? The paper gasket between the alternator body and the rear cover? Or the elbow between the impeller housing and the rear cover? |
kconway |
Apr 23 2010, 09:57 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I am IN for both. And I'll be a repeat customer on those for sure. Pretty much every snorkel out there is toast. While a split snorkel would be neat and dead simple to install, the rear section of the harness is REALLY simple to pull. I'd also be more nervous of the split snorkel coming undone later. QUOTE I asked Mark about doing the "suction housing" gasket for the alternator recently since its NLA. Which one is that? The 'ring' between the alternator body and the engine tin? The paper gasket between the alternator body and the rear cover? Or the elbow between the impeller housing and the rear cover? I'm thinking about the 'ring' between the alternator body and engine tin. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:19 AM |
