One more new item -Actually a few, Delrin roller and bushing for clutch cable $14.50 / $4 |
Mikey914 |
Apr 26 2010, 08:32 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I was replacing my clutch cable pulley as it was brittle and the edge broke out. So I decided to do up a few of these. This is a machined Delrin pulley that will replace the OEM. It will have less flex that the OEM. It is also much more sturdy. I'm also making the bushing that goes in the center as I went to buy a new one to make sure it was within tolerance for the bushing, and guess what NLA. They are not a standard size pipe that you could just cut and use, so I decided to machine down a few to make these available in stainless. If you want a spare in case you loose one now is a good time as they're cheaper than OEM were.
Thought I'd introduce these as there were a few other parts that were coming out that I could combine shipping on. I will have the heater knobs in 2 days, and the scissor window roller bushings. I will start threads on these as soon as I get them done. Sign up here for the clutch cable pulley or just the bushing. Shipping will be flay rate envelope at $5 Attached thumbnail(s) |
Eric_Shea |
Apr 28 2010, 03:13 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Throw them in the box marked "Eric"
Lo-Fi Version | Time is now: 11th June 2024 - 09:47 PM |
