> 914/6 conversion gremlin
rfuerst911sc
post May 3 2010, 05:53 PM
Over the weekend my 3.0 conversion started running like crap. Almost instantly it went from running good to crap. Seems like it is not running on all cylinders. On Sunday I installed new spark plugs but that made no difference and the old plugs ( less than 3 months old ) looked fine. When I restarted after the new plugs the car would not turn off when I turned the ignition off ? She finally died on her own from the poor running. So I decided to put my battery tender on as the battery seemed low ( less than 1 month old ). Today when I got home from work I noticed the alternator light on the dash was lit with the key off.....wtf ??? So the battery is new,spark plugs new along with ignition wires,coil. The ignition box is a Mallory digital being driven by a recurved Jerry Woods distributor. And the alternator was rebuilt by a local shop. Any ideas what's going on ?
iamchappy
post May 3 2010, 08:50 PM
It all happens so fast!
You may want to put an inline one way diode on the wire that runs to the Alt light. blue wire i think, voltage is leaking and supplying the electric ignition causing the run on.
I would check to see if your dizzy is loose maybe the hold down nut has backed off.
Also recheck the condition of your plug wires, i have had wires that looked fine from the outside but were bad.
Read up on run on and causes
http://www.msdignition.com/page.aspx?id=3296
rfuerst911sc   914/6 conversion gremlin   May 3 2010, 05:53 PM
sixnotfour   wiring / junk in carbs :confused:   May 3 2010, 08:41 PM
kg6dxn   I'm thinking you have lost electrical ground t...   May 3 2010, 08:50 PM
iamchappy   You may want to put an inline one way diode on the...   May 3 2010, 08:50 PM
rascobo   A lot of notoriously bad ignition switches out the...   May 3 2010, 09:10 PM
dr914@autoatlanta.com   I think that the voltage regulator went waco, over...   May 4 2010, 07:57 AM
charliew   First like George said you might want to check the...   May 4 2010, 08:23 AM
Jeffs9146   Isn't the 3.0 alternator internaly regulated??   May 4 2010, 09:28 AM
Justinp71   Try cleaning out your idle jets first! Make su...   May 4 2010, 11:16 AM
Root_Werks   When you shut the engine off, was it run-on or run...   May 4 2010, 03:08 PM
Dave_Darling   Did you do anything to the car (particularly anyth...   May 4 2010, 08:29 PM
carr914   Rick, since you were having some electrical proble...   May 4 2010, 08:37 PM
rfuerst911sc   I called Donnie at Zotz yesterday and he thinks tw...   May 5 2010, 05:42 AM
carr914   Idle Jets will take you 10 minutes to take out cle...   May 5 2010, 08:05 AM
rfuerst911sc   Idle Jets will take you 10 minutes to take out cl...   May 5 2010, 10:16 AM
carr914   Yes, #4. Unscrew it, Don't drop the tiny rubbe...   May 5 2010, 10:36 AM
rfuerst911sc   UPDATE- Well I tried chasing my issues but could n...   May 12 2010, 06:54 PM
bcheney   I guess I have some drama to look forward to...   May 12 2010, 07:52 PM
messix   quickest short cut in electrical trouble shooting ...   May 12 2010, 08:14 PM
- Lo-Fi Version Time is now: 14th April 2026 - 07:35 PM
