> 914/6 conversion gremlin
rfuerst911sc
post May 3 2010, 05:53 PM
Over the weekend my 3.0 conversion started running like crap. Almost instantly it went from running good to crap. Seems like it is not running on all cylinders. On Sunday I installed new spark plugs but that made no difference and the old plugs ( less than 3 months old ) looked fine. When I restarted after the new plugs the car would not turn off when I turned the ignition off ? She finally died on her own from the poor running. So I decided to put my battery tender on as the battery seemed low ( less than 1 month old ). Today when I got home from work I noticed the alternator light on the dash was lit with the key off.....wtf ??? So the battery is new,spark plugs new along with ignition wires,coil. The ignition box is a Mallory digital being driven by a recurved Jerry Woods distributor. And the alternator was rebuilt by a local shop. Any ideas what's going on ?
dr914@autoatlanta.com
post May 4 2010, 07:57 AM
I think that the voltage regulator went waco, overcharged the battery (accounting for the poor running, too much voltage) then crapped out frying the alternator. That is why the light is on and the battery low. Please check for a battery acid spill with baking soda and water around the base of the battery as the acid may have boiled out!!!
QUOTE(rfuerst911sc @ May 3 2010, 04:53 PM) *
rfuerst911sc   914/6 conversion gremlin   May 3 2010, 05:53 PM
sixnotfour   wiring / junk in carbs :confused:   May 3 2010, 08:41 PM
kg6dxn   I'm thinking you have lost electrical ground t...   May 3 2010, 08:50 PM
iamchappy   You may want to put an inline one way diode on the...   May 3 2010, 08:50 PM
rascobo   A lot of notoriously bad ignition switches out the...   May 3 2010, 09:10 PM
dr914@autoatlanta.com   I think that the voltage regulator went waco, over...   May 4 2010, 07:57 AM
charliew   First like George said you might want to check the...   May 4 2010, 08:23 AM
Jeffs9146   Isn't the 3.0 alternator internaly regulated??   May 4 2010, 09:28 AM
Justinp71   Try cleaning out your idle jets first! Make su...   May 4 2010, 11:16 AM
Root_Werks   When you shut the engine off, was it run-on or run...   May 4 2010, 03:08 PM
Dave_Darling   Did you do anything to the car (particularly anyth...   May 4 2010, 08:29 PM
carr914   Rick, since you were having some electrical proble...   May 4 2010, 08:37 PM
rfuerst911sc   I called Donnie at Zotz yesterday and he thinks tw...   May 5 2010, 05:42 AM
carr914   Idle Jets will take you 10 minutes to take out cle...   May 5 2010, 08:05 AM
rfuerst911sc   Idle Jets will take you 10 minutes to take out cl...   May 5 2010, 10:16 AM
carr914   Yes, #4. Unscrew it, Don't drop the tiny rubbe...   May 5 2010, 10:36 AM
rfuerst911sc   UPDATE- Well I tried chasing my issues but could n...   May 12 2010, 06:54 PM
bcheney   I guess I have some drama to look forward to...   May 12 2010, 07:52 PM
messix   quickest short cut in electrical trouble shooting ...   May 12 2010, 08:14 PM
- Lo-Fi Version Time is now: 14th April 2026 - 09:12 PM
