| rfuerst911sc |
May 3 2010, 05:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Over the weekend my 3.0 conversion started running like crap. Almost instantly it went from running good to crap. Seems like it is not running on all cylinders. On Sunday I installed new spark plugs but that made no difference and the old plugs ( less than 3 months old ) looked fine. When I restarted after the new plugs the car would not turn off when I turned the ignition off ? She finally died on her own from the poor running. So I decided to put my battery tender on as the battery seemed low ( less than 1 month old ). Today when I got home from work I noticed the alternator light on the dash was lit with the key off.....wtf ??? So the battery is new,spark plugs new along with ignition wires,coil. The ignition box is a Mallory digital being driven by a recurved Jerry Woods distributor. And the alternator was rebuilt by a local shop. Any ideas what's going on ?
| Justinp71 |
May 4 2010, 11:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
Try cleaning out your idle jets first! Make sure your running good fuel filters, I have one at the tank and one before going into each carb. Also cleaning the tank can do wonders... an easy way to tell if its the idle jets is to get in and drive, the motor will kick in over 3k rpms... |
rfuerst911sc 914/6 conversion gremlin May 3 2010, 05:53 PM
sixnotfour wiring / junk in carbs :confused: May 3 2010, 08:41 PM
kg6dxn I'm thinking you have lost electrical ground t... May 3 2010, 08:50 PM
iamchappy You may want to put an inline one way diode on the... May 3 2010, 08:50 PM
rascobo A lot of notoriously bad ignition switches out the... May 3 2010, 09:10 PM
dr914@autoatlanta.com I think that the voltage regulator went waco, over... May 4 2010, 07:57 AM
charliew First like George said you might want to check the... May 4 2010, 08:23 AM
Jeffs9146 Isn't the 3.0 alternator internaly regulated?? May 4 2010, 09:28 AM
Root_Werks When you shut the engine off, was it run-on or run... May 4 2010, 03:08 PM
Dave_Darling Did you do anything to the car (particularly anyth... May 4 2010, 08:29 PM
carr914 Rick, since you were having some electrical proble... May 4 2010, 08:37 PM
rfuerst911sc I called Donnie at Zotz yesterday and he thinks tw... May 5 2010, 05:42 AM
carr914 Idle Jets will take you 10 minutes to take out cle... May 5 2010, 08:05 AM
rfuerst911sc
Idle Jets will take you 10 minutes to take out cl... May 5 2010, 10:16 AM
carr914 Yes, #4. Unscrew it, Don't drop the tiny rubbe... May 5 2010, 10:36 AM
rfuerst911sc UPDATE- Well I tried chasing my issues but could n... May 12 2010, 06:54 PM
bcheney I guess I have some drama to look forward to... May 12 2010, 07:52 PM
messix quickest short cut in electrical trouble shooting ... May 12 2010, 08:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 07:35 PM |
