| rfuerst911sc |
May 3 2010, 05:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Over the weekend my 3.0 conversion started running like crap. Almost instantly it went from running good to crap. Seems like it is not running on all cylinders. On Sunday I installed new spark plugs but that made no difference and the old plugs ( less than 3 months old ) looked fine. When I restarted after the new plugs the car would not turn off when I turned the ignition off ? She finally died on her own from the poor running. So I decided to put my battery tender on as the battery seemed low ( less than 1 month old ). Today when I got home from work I noticed the alternator light on the dash was lit with the key off.....wtf ??? So the battery is new,spark plugs new along with ignition wires,coil. The ignition box is a Mallory digital being driven by a recurved Jerry Woods distributor. And the alternator was rebuilt by a local shop. Any ideas what's going on ?
| rfuerst911sc |
May 5 2010, 05:42 AM
I called Donnie at Zotz yesterday and he thinks two issues going on. Might be clogged idle jets and a bad ignition switch. I'm swamped at work but I need to find time to put her on the trailer and get her over to Zotz. I do have a spare Mallory ignition box. TC I assume your gremlins are running behind on schedule ?
rfuerst911sc 914/6 conversion gremlin May 3 2010, 05:53 PM
sixnotfour wiring / junk in carbs :confused: May 3 2010, 08:41 PM
kg6dxn I'm thinking you have lost electrical ground t... May 3 2010, 08:50 PM
iamchappy You may want to put an inline one way diode on the... May 3 2010, 08:50 PM
rascobo A lot of notoriously bad ignition switches out the... May 3 2010, 09:10 PM
dr914@autoatlanta.com I think that the voltage regulator went waco, over... May 4 2010, 07:57 AM
charliew First like George said you might want to check the... May 4 2010, 08:23 AM
Jeffs9146 Isn't the 3.0 alternator internaly regulated?? May 4 2010, 09:28 AM
Justinp71 Try cleaning out your idle jets first! Make su... May 4 2010, 11:16 AM
Root_Werks When you shut the engine off, was it run-on or run... May 4 2010, 03:08 PM
Dave_Darling Did you do anything to the car (particularly anyth... May 4 2010, 08:29 PM
carr914 Rick, since you were having some electrical proble... May 4 2010, 08:37 PM
carr914 Idle Jets will take you 10 minutes to take out cle... May 5 2010, 08:05 AM
rfuerst911sc
Idle Jets will take you 10 minutes to take out cl... May 5 2010, 10:16 AM
carr914 Yes, #4. Unscrew it, Don't drop the tiny rubbe... May 5 2010, 10:36 AM
rfuerst911sc UPDATE- Well I tried chasing my issues but could n... May 12 2010, 06:54 PM
bcheney I guess I have some drama to look forward to... May 12 2010, 07:52 PM
messix quickest short cut in electrical trouble shooting ... May 12 2010, 08:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:12 PM |
