Quieter mufler?, without loosing too much power? |
VaccaRabite |
Apr 24 2010, 08:52 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am running a EruoRace header, and the "Turbo" muffler is LOUD. Ear plugs needed on the freeway loud. yes, it sounds mean, but it makes the car rather uncomfortable to drive for longer rides.
I would like to cut it off, and replace it with something a bit more quiet, but that will still work in the spot and allow me to use the stock exhaust exit in the rear valiance. Any ideas? Zach |
GS Guy |
May 7 2010, 01:45 PM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
My experience with mufflers in general, especially low restriction mufflers:
Bigger = Quieter If you could fit (tow?? (IMG:style_emoticons/default/biggrin.gif) ) a trailer size empty BOX on the back, with just an inlet and outlet matching the size of your exhaust, I'd bet it would be whisper quiet! But we're all limited on space. So it comes down to either OEM (pick a high output engine from and OEM manufacturer to choose that muffler from), or the biggest high flow aftermarket muffler that'll fit. The 'trapp might be a good idea, basically adding a 2nd muffler, and you could "quiet" it further adding more restriction with fewer plates. Might do some funkiness to the carb jetting though???? (IMG:style_emoticons/default/confused24.gif) Jeff |
ChrisFoley |
May 7 2010, 04:06 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
My experience with mufflers in general, especially low restriction mufflers: Bigger = Quieter If you could fit (tow?? (IMG:style_emoticons/default/biggrin.gif) ) a trailer size empty BOX on the back, with just an inlet and outlet matching the size of your exhaust, I'd bet it would be whisper quiet! But we're all limited on space. So it comes down to either OEM (pick a high output engine from and OEM manufacturer to choose that muffler from), or the biggest high flow aftermarket muffler that'll fit. This is probably the biggest muffler that will fit well under a 914. It is also about the quietest available, except for (possibly) the OEM units. It is without a doubt the most free flowing, since it doesn't add any length to the primaries and has nearly zero internal restriction. Oh, yeah - it is quite likely the most expensive muffler available for the 4 cyl. HEs too. (IMG:style_emoticons/default/happy11.gif) And until someone else orders one I will be the only person enjoying it on their daily driver. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:36 PM |
