914 V8 cooling, overheating issues |
John2kx |
Mar 7 2004, 07:51 AM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Howard,
I run a Renegade cooling system and have had overheating issues along the way. Most were due to problems caused by myself. I'll post some pics of my system and be glad to share what I have learned the last year and a half. First pic is of water sender location. I actually run two gauges. The two brass fittings are my temperature monitor points. Since the water from pump is routed into block, to heads and then to intake prior to moving back to radiator, the intake is the preferred location of sender. John Attached image(s) |
Howard |
Mar 7 2004, 09:47 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
OK, this can't be right. Temp sensor nestled between exhaust ports? No shit it's hot! Is this a normal location? Looked around thermo housing, no wires there and pulling this turned of the gauge.
Lo-Fi Version | Time is now: 17th June 2024 - 01:04 AM |
