F^&*^&*^ing exhaust head studs- Distributor ?, My distributor is off 1/4 turn. How to fix? |
JRust |
May 1 2010, 04:18 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay I officially pulled an dipshit move today. I was putting my drivetrain all together to be ready to install in my LE. All was going great as I had Mr Kona down helping me today. We got the transmission mounted. Put on the passenger side SS (bolted in place by Brian) & all was great. We change spots & I do the drivers side. I've got all the nuts on & am bolting into place. I have my torque wrench on there & am tightening away. It is was to big for the job but I figure all is well. Well I am a dipshit as I overtightened one & snaped the bolt (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I do have some nice stud pullers sowhile pissed for being an idiot. I figure I can get it out without to much trouble.
Hell no I can't. Even after some heat my stud snaps again at the head. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I then try to get under there & drill a hole to use an extractor. My extractor breaks in the hole I drilled. SO now I have to drill that out too. I am so frustrated & it's my own damn fault. I'm going to head to harbor freight & pick up a new tap & dye set. Any ideas on how to not screw this up any worse (IMG:style_emoticons/default/dry.gif) |
bandjoey |
May 7 2010, 09:28 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
This hasn't been talked about here but..someone in the know needs to chime in.
It's something that JRust might need to know before he get's too much further. I've been told to get the right torque on the lifter bolts, each valve needs to be at (tdc, etc) a special place. Otherwise, you're torquing against an open valve and the lifters will be loose after that valve moves. Is this right or wrong? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
May 7 2010, 09:39 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
This hasn't been talked about here but..someone in the know needs to chime in. It's something that JRust might need to know before he get's too much further. I've been told to get the right torque on the lifter bolts, each valve needs to be at (tdc, etc) a special place. Otherwise, you're torquing against an open valve and the lifters will be loose after that valve moves. Is this right or wrong? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) As long as he follows the haynes manual, he will be fine. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:22 PM |
