JRust
May 1 2010, 04:18 PM
r_towle
May 1 2010, 04:30 PM
get left handed cobalt drill bits or carbide drill bits...get a left handed set...
As you drill, you end up loosening the stud.
Why do you think Len hates used heads...
Rich
McMark
May 1 2010, 06:54 PM
Bad news. The extractor is VERY hard will eat your drill bits and laugh at you, or worse, will FORCE your drill bits off center and make you drill into the head meat.
It
REALLY REALLY sucks, but I'd stop. Take a couple days off, then pull the motor and get the head off and let someone else deal with it. You're problem CAN get a lot worse.
I wish I could tell you there's a quick fix, but there's not and you'll be much better off by taking the longer route on this.
JRust
May 1 2010, 07:05 PM
I didn't know they made drill bits left handed
. I will try to find some. Would home depot carry that?
On the extractor I will see. I am taking a break now & was feeling better. Until Macmark told me I am going to have to pull my head
. I am going to give drilling it out a try tommorow. The extractor I had I think was kind of a cheap old thing. So hopefully that is why it broke & I will be able to get it out. Whatever I do will be slow & methidical. These are rebuilt heads & I'll be damned if I am going to screw them up
I'm over bein pissed as there's not much I can do about it now. Other than not make it any worse.
r_towle
May 1 2010, 07:20 PM
home depot wont carry left handed bits.
McMaster will.
First, find a way with picks to try and loosen the extractor and get it out of the way.
Rich
VaccaRabite
May 1 2010, 07:21 PM
Pull the head. Let someone one that can put it in a jig and hit it will his mill drill out the bolt and extractor.
If you go off center, you are going to be into it for $$$, as you will have to get the head welded and rebuilt.
Zach
JRust
May 1 2010, 08:38 PM
McMark was right. The extractor is some hard stuff. Drill bit wouldn't touch it. Picks aren't going to get it out either. I think if I had the extractor out I could get it. Big shocker that using the extractor wasn't my smartest move. Especially considering how the stud wouldn't budge with my stud puller. I shouldn't have even tried the damn extractor
. So yes off comes the head.
It does suck to be sure. I guess it's a learning experience though right
Okay well I need to read up on pulling the head. I should have learned this by now. If I have any prayer of getting it back soon I need to get it pulled & to a machine shop monday. I'll read up in my haynes but if you want to give me the rundown on taking it off thats great.
underthetire
May 1 2010, 08:48 PM
Only 3 ways to get that extractor out now.
A dremel with a small grinding bit and a lot of time.
a carbide drill on a mill, don't try to use carbide with a hand drill, you'll be sorry.
A EDM (electrical discharge machine) Some special shops do tap extraction ( same material) call around for precision machine shops.
They used to sell TAP OUT witch you basically made a dam with some putty around the broken tap/extractor and filled the inside with a special acid. The acid didn't touch aluminum, just steel. This takes several days.
Good luck man, I drilled two broken ones out about a month ago.
underthetire
May 1 2010, 08:57 PM
here is some info, guess its just nitric acid
http://yarchive.net/metal/tap_remove.htmlIt actually does work. Used this method for years before we had EDM's
MrKona
May 1 2010, 09:00 PM
Hey Jamie,
On my way home today, I was thinking, "He's gonna have to pull the head..."
You're going to have to remove the tin pieces that screw into that head, and of course, all the pieces that screw onto the pieces that screw onto the head..
After that, you need to remove the rockers, pushrods (keep them together for reassembly) pushrod tubes, and under-the-head tin (that tin also screws onto the heads). Then the stud nuts that hold the heads on. Then the head should pull right off.
- Bryan
JRust
May 1 2010, 09:05 PM
QUOTE(MrKona @ May 1 2010, 08:00 PM)
Hey Jamie,
- Bryan
I don't have to do anything with the valves right
MrKona
May 1 2010, 09:06 PM
QUOTE(JRust @ May 1 2010, 07:05 PM)
Hey Jamie,
- Bryan
Nope.
JRust
May 1 2010, 09:10 PM
Piece of cake then. I'll pull it tommorow. Then find a place machine shop on monday when I go to work. Hopefully they wont ding me to badly for the work
Ah crap I need to order some more parts now. Since it hasn't been run since it's been rebuilt. Will I need to replace the copper seal/seat between the heads & piston jugs? Then I need a new valve cover gasket (I know as it ripped coming off), Push rod tube seals. Anything else?
aircooledtechguy
May 1 2010, 09:23 PM
I feel your pain. . .
Taps are tough, but ONLY because of their heat treatment. You can anneal the tap by hitting it with a torch so it glows and allowing it to cool on its own. Then you can drill right through them like any other steel.
I've done this several times over the years with other bolts on cars. Once you hit it with a torch so it glows, you can drill right through them. 'Course this will be a LOT easier with the head off and on a bench. . .
Good Luck!!
McMark
May 1 2010, 10:55 PM
1. Pull the motor.
2. Remove the intake runner on that side.
3. Remove the engine tin on that side (top piece, and the front and rear pieces, you'll need to remove the fan housing)
4. Take off the valve cover.
5. Remove the four nuts that hold on the rockers.
6. Remove the pushrods.
7. Remove the pushrod tubes.
8. Remove the under cylinder tin.
9. Take off the head nuts.
10. Slide the head off.
For reassembly, choose if you want to attempt to apply sealant to the surface between the cylinders and the block. This area
could leak later, but it's not too common of a leak point, so it's not a huge risk. If you're going to do it, pull the cylinders and clean up any old sealant and do it right.
You'll need new sealing gaskets if you're using those (I have some I can send you). Install those and slide the head into place. Apply some sealant to the lower head washers and head nuts. Torque the head nuts to 13 ft/lbs, then to 24 ft/lbs (check Haynes for the pattern).
Install the under cylinder tin.
Install the pushrod tubes.
Install the pushrods.
Install the rockers and the pushrod retaining wire.
Adjust the valves.
Install the valve cover.
Install the engine tin.
Install the fuel injection.
Install the motor.
Install the exhaust. (Using a 1/4" socket wrench, never 3/8")
Best of luck. You'll be okay, and so will your motor. Work slow, don't worry about WCR or any other deadline. If you make it, it was meant to be. If you don't, you can still come and I'll buy you a BIG beer. :beer:
Same thing happened to me in the 80s i used masonary drill bits with the flat carbide end drill slow will take time but will work
JRust
May 2 2010, 01:48 AM
QUOTE(McMark @ May 1 2010, 09:55 PM)
1. Pull the motor.
Adjust the valves.
Install the motor.
If It doesn't make WCR oh well. I'd like to be in it & obviously take it on the drives. Not critical to me having a good time. Although it would help
Thanks for the nicely written breakdown. I did try heating the stud & was able to drill into it fine before I tried the extractor. Just wasn't meant to be
I'll get it to a machine shop & see how it goes. I still have enough time to get everything together if I get it back quickly. If I can't find a place that can do it right away is what worries me
. If I can't get a place to do it by midweek I'll be hosed. Even then I may just put another motor in to come
sww914
May 2 2010, 02:12 AM
There is another way.
I've done it 100 times on various broken studs.
With the head off you can put an 8mm nut on top of the broken stud and mig weld the nut to the broken stud, through the hole and fill the nut up all the way to the top.
Hit it with an impact gun to unscrew the broken stud. Most likely it will just extract the broken easy-out so weld another nut on. It will probably break off so do it again. It will probably break off again so do it again. It might take 10 tries. Or 20. Each time the heat expands the stud and crushes the corrosion more than the last time, getting you closer to your goal.
Even 30 8mm nuts are cheaper than a trip to the machine shop and cheaper than ruining your head with a drill bit drifting off to the side.
Good thing steel mig welds won't stick to your aluminum head, isn't it?
This process is so quick and easy if the part isn't upside down that I don't usually charge my customers to extract the broken fastener unless it's really bad.
TheCabinetmaker
May 2 2010, 07:58 AM
Pushrods must be reinstalled exactly like they come out.
McMark
May 2 2010, 10:19 AM
Steve's got a good technique there.
Jamie,
Sorry to hear this. Take a breath, or break. I know you are somewhat in a hurry so you can drive this , but the extra time spent now will seem like ice cream if your hurry causes another problem.
This almost happened to me before I even knew about the dreaded exhaust stud breaking issue. I was extremely lucky and stopped and researched before doing anything else. Whew! Just be careful.
Good luck,
Tom
MartyYeoman
May 2 2010, 10:43 AM
QUOTE(McMark @ May 1 2010, 05:54 PM)
It
JRust
May 2 2010, 11:55 AM
Okay I just pulled the head. Was pretty easy I must admit. Here are pics of the carnage. I didn't have the motor in the car yet. I was putting everything on before install. Which as it turned out wasn't a bad idea
. At least I didn't have to drop the motor to pull the head.
Being this hasn't been run since the rebuild. Are the large cylinder crush washers
toast? So I should replace those? How about the push rod tube seals?
VaccaRabite
May 2 2010, 12:08 PM
Do yourself a favor. Write ON each pushrod what bore it came out of with a sharpie. Even if they are in order now, they could get kicked, knocked or otherwise jumbled. they need to go back into the same bore they came out of.
You are on the right path. I bet the acid would work if you can find it and have a few days to spare. otherwise, off to the shop you go.
Zach
McMark
May 2 2010, 10:45 PM
Why do people think the pushrods have to go back in the same bore? They're all the same length and they aren't a wear item. Lifters need to go back in the same place when they get pulled because they 'wear in' with the cam. The pushrods aren't like that.
messix
May 2 2010, 10:50 PM
QUOTE(McMark @ May 2 2010, 09:45 PM)
oh but they do "wear" in the cup of the rocker.
better safe than sorry!
computers4kids
May 3 2010, 07:37 AM
Jamie,
You might consider replacing the other head studs unless you think the mechanic just use too much force
Dang, I'm always scared of snapping a stud...I've read too many threads with this story.
Believe it or not, I actually use a 1/4 drive rachet when dealing wtih the exchangers...I like to really feel how much pressure I'm applying.
I wish you the best my friend; I know how much you want to bring your LE to the WCR.
Mark
JRust
May 3 2010, 08:02 AM
Mcmark mentioned using a 1/4 inch ratchet on it too. I think that is a very smart idea. This was totaly my fault to be sure. I was using my torque wrench at 14lbs & I didn't hear or feel it click like it is supposed to. It also is a huge 1/2" drive as that was the only torqe wrench I owned. So it was a combination of all. If I had used a smaller one I would have had no problem. Using such a big ratchet took all the feel out of it. I still should have been more careful. I was a little excited bolting it up & having it come together after so long
. I'm still pretty pissed at myself about it. Besides pulling the head so I could take it in today. I didn't do anything else to the LE. Just not in a good frame of mind to be down there by it.
I'll feel better once I get the head back & put it back together
RoadGlue
May 3 2010, 08:54 AM
QUOTE(McMark @ May 2 2010, 08:45 PM)
I'm with Mark here. I've never given second thought about push rod order when doing repairs like this. I can't say it has ever come back to bite me in the butt either.
Jrust - I had the same problem as you (though my stud broke during a collision) and had to pull the motor to have the stud (and more) fixed. I just got it back together last week. I didn't replace the cylinder shims. I was a little worried about there being an oil leak, but so far it doesn't look like it's leaking.
charliew
May 3 2010, 09:36 AM
I once used every 1/2 and 5/8 nut I had on a sbc head in a blazer trying to get the rear most exhaust stud out. I used a ac crackerbox stick welder, it was the easiest to use in the spot I was in. I had the inner fender wheelwell off, it is close to the ac/heater box on the firewall. Ended up it had two easy outs in it and one 1/4 tap? from a po. It did come out but the po made such a mess I had to use a helicoil.
charliew
May 3 2010, 09:43 AM
For all you know the stud was weakened when it was taken apart. Exhaust studs get soft from heat. I wonder who did your heads. The keepers and retainers and springs look like the varnish was never cleaned off or the combustion chambers were not checked for cracks? If all the push rods are known to be the same length it shouldn't matter as the lash will have to be set anyway. I have always tried to find copper or brass nuts to use on exhaust studs to prevent the siezing on the studs and they are pretty soft. I'm not sure they are as soft as the aluminum though. Chev exhaust pipe studs in the cast iron heat risers and manifolds are where I got most of my initiation on weak exhaust studs, at least I wasn't also dealing with a aluminum mounting piece.
Root_Werks
May 3 2010, 09:47 AM
So close!
Keep at it.
JRust
May 3 2010, 01:11 PM
Went by a machine shop & they sent me to another place. This place has an EDM
something they zap the stud with electricity while drilling or something. I don't know how they do it & don't care. When I dropped it off they said no problem. Should be less than a $100 & we'll have it this afternoon
. I'm feeling much better. I'll feel even better when I get it back & they really did get it without a problem
ClayPerrine
May 3 2010, 01:40 PM
EDM is the way to go. They will be able to remove the broken stud and not touch the threads.
Be careful with the new stud.
MrKona
May 3 2010, 02:15 PM
Jamie,
That's great news. FYI - I have a new 8mm stud that I won't use (my heads take 10mm/8mm step studs). I just dropped it in the mail to you so you don't have to fiddle with a used stud.
Hopefully you'll have it tomorrow.
- Bryan
McMark
May 3 2010, 02:34 PM
This is GREAT NEWS!. EDM is awesome and really is the best way to go here. I had this EXACT series of events way back when on my 928.
Cap'n Krusty
May 3 2010, 03:03 PM
Check the hole for fit when you get it back. We use a VERY GOOD EDM guy, and he warns us to do so. Last go-round we had to helicoil 5 of the 8 holes he did.
The Cap'n
Root_Werks
May 3 2010, 03:13 PM
And of course you meant TimeCert right Krust.
JRust
May 3 2010, 05:43 PM
QUOTE(MrKona @ May 3 2010, 01:15 PM)
Jamie,
- Bryan
Thanks Bryan that is perfect.
Well it didn't go perfectly at the shop. The threads were not in good shape. They went ahead & put a helicoil in it. I am fine with it though. Also it only ran $65 so I can't complain. I had to leave work & head north on some service stuff. So I can't pick it up till tommorow.
On a semi related note I may go pick up a 74 2.0 parts car tonight
. Motor is torn apart & it's missing one head & the Fuel injection
. The FI would have come in handy
.I'm hoping I'll get lucky & find it somewhere in his shop.
JRust
May 4 2010, 09:29 PM
Picked up the head today & it looks great
. I got home a little to late to do anything tonight. I'll be putting it back on tommorow night. Got a few seals to pick up at the local vw place to be safe.
Root_Werks
May 5 2010, 01:54 PM
Cool! Be nice to see your LE. I think Rich is pretty close to having his on the road as well.
LE's rock!
biosurfer1
May 5 2010, 01:59 PM
Isn't it fun to pay a bunch of money have something back to way it already was?
...I've been there. Glad your's is getting there!
JRust
May 5 2010, 11:01 PM
Okay so I installed my head & pushrod tubes. I had my haynes out & I see intall the pushrods retaining clip
. I know there was not one in there when I pulled my head to begin with
. How critical is it? I guess I'm going to have to pul my other valve cover just to see if that side has it
RoadGlue
May 5 2010, 11:18 PM
Ignore that photo for the most part. Once the rocker assemblies are in place the clips will have something to attach to. You can put the rockers in before you put the clip in. The clip will bend enough to where it can be installed last. Just make sure the flat bits on the bottom of the clip are flush up against the push rod tubes. It's easy for them to slip during installation and to end up in the tube vs. against the lip of the tube.
You're almost there!
McMark
May 5 2010, 11:46 PM
Worst case scenario, if you leave it out, you MIGHT have a small oil leak. So it's not really a big deal. If you don't have them, add them to your shopping list, but don't stress it.
JRust
May 6 2010, 08:20 PM
Does it matter how the rocker ends bolt on? I just noticed I have 3 one way & the 4th the other
& yes I still need to adjust my valves
ClayPerrine
May 6 2010, 08:54 PM
Yes, it does matter. the blocks should have the slots on the bottom. The spring fits into the slots when it is installed.
r_towle
May 6 2010, 09:37 PM
What is the different color goo?
IC white and blue goo???
Rich
McMark
May 6 2010, 09:44 PM
All of those are wrong.
messix
May 6 2010, 09:58 PM
QUOTE(r_towle @ May 6 2010, 08:37 PM)
Rich
rtv
