F^&*^&*^ing exhaust head studs- Distributor ?, My distributor is off 1/4 turn. How to fix? |
JRust |
May 1 2010, 04:18 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay I officially pulled an dipshit move today. I was putting my drivetrain all together to be ready to install in my LE. All was going great as I had Mr Kona down helping me today. We got the transmission mounted. Put on the passenger side SS (bolted in place by Brian) & all was great. We change spots & I do the drivers side. I've got all the nuts on & am bolting into place. I have my torque wrench on there & am tightening away. It is was to big for the job but I figure all is well. Well I am a dipshit as I overtightened one & snaped the bolt (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I do have some nice stud pullers sowhile pissed for being an idiot. I figure I can get it out without to much trouble.
Hell no I can't. Even after some heat my stud snaps again at the head. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I then try to get under there & drill a hole to use an extractor. My extractor breaks in the hole I drilled. SO now I have to drill that out too. I am so frustrated & it's my own damn fault. I'm going to head to harbor freight & pick up a new tap & dye set. Any ideas on how to not screw this up any worse (IMG:style_emoticons/default/dry.gif) |
JRust |
May 8 2010, 02:08 PM
Okay I got my valve's set fine. I put everything back together & have my tin back on. It's ready for the SS HE to be bolted back on (VERY CAREFULLY (IMG:style_emoticons/default/mad.gif) ). I started putting my FI on. I had to pull the cylinder head temp sensor off my 73 as this one didn't have it. No problem although I had to pull the tin AGAIN. LOL
I did notice between going from one motor to the other. My LE motor has the distributor sitting 1/4 turn differently than my 73. I am sure it is wrong on my 74. My friend who rebuilt it for me apparantlt got it in wrong. I need to fix it but am not entirely sure how to do it without completely screwing things up (IMG:style_emoticons/default/dry.gif) . Here are pics Attached image(s) |
70_914 |
May 8 2010, 02:13 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Okay I got my valve's set fine. I put everything back together & have my tin back on. It's ready for the SS HE to be bolted back on (VERY CAREFULLY (IMG:style_emoticons/default/mad.gif) ). I started putting my FI on. I had to pull the cylinder head temp sensor off my 73 as this one didn't have it. No problem although I had to pull the tin AGAIN. LOL I did notice between going from one motor to the other. My LE motor has the distributor sitting 1/4 turn differently than my 73. I am sure it is wrong on my 74. My friend who rebuilt it for me apparantlt got it in wrong. I need to fix it but am not entirely sure how to do it without completely screwing things up (IMG:style_emoticons/default/dry.gif) . Here are pics Are your block and fan shroud painted or just that clean? Looks nice either way... |
Lo-Fi Version | Time is now: 8th June 2024 - 03:04 PM |
