creating new susp for the monster, going dual A setup front and rear |
byndbad914 |
Mar 31 2010, 02:19 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Car currently has RSR front struts with custom lower arm setup (sorta like a 935 front end) and the rear is a 5-link setup that is much like any old school 60s-80s open wheel car, GT-40, etc all attached to my tube chassis setup.
Decided I wanted to lower the car more and fix a couple issues with the rear 5-link geom so I started laying out some parts, then decided F it, time for a whole new update (IMG:style_emoticons/default/laugh.gif) I can't leave anything alone. So I measured various available pickup points on the current chassis and whipped up this stuff in Pro/Engineer. The lower A is already a bit different than I have assembled in here, but close enough for convo - and JP was asking to see what I have going - I am sure so he can raz me about whether or not I actually win at DEs (IMG:style_emoticons/default/happy11.gif) I used Pro to lay out the geometry so I could measure camber gain, get zero toe positions for the toe link (which will be adjustable in case I want to put some bumpsteer into the rear), RC height and motion, etc. Is this perfectly optimal on all points? Hell no, but much better than what I have and works with existing structure - I am not about to really hack into this car. I can get tabs waterjet cut and welded into place, but not bending/notching tubes in my near future. Besides, it leaves me a little bit of excuse for why I am slow on the track cuz it certainly isn't my driving abilities hahaha (IMG:style_emoticons/default/driving.gif) So here is the rear design - it will be built using the stock trailing arm cut down to not much more than a bearing carrier. yeah, yeah, use this other thing, make that, blah blah - the stock rear bearing assy has worked for a few years now so it is fine. I intend to replace that big bearing every few years regardless of upright used anyways. I did the same layout stuff for the front and even am going to be able to use the exact same billet lower A front and rear so that is nice. I can have them waterjetted for about $170 each including the 1.5" plate material, so not bad at all. I bought a couple front strut housings from Carquip last week and had my machinist buddy endmill out that monster weld so gonna work on getting them apart down to the stock knuckle, then I have 2" diam chromoly I just got yesterday that I will have him machine down to make the front "upright". Note the two surface colors in the above image - the blue is turned down to fit in the knuckle (50mm) and the green is the stock 2" diam of the tubing - that ridge will be used to exactly place the tube relative to the knuckle so I get both spindles left to right in the exact same spot. The upper forward link will be made on the fly so I didn't bother modeling it. I need to get this stuff in the car with the right pickup points placed, then place some dual adjustable coil over assys which might be tough on the front, then build the forward link around the shock assy. At some point you stop fisting the design and just build it (IMG:style_emoticons/default/shades.gif) Being a structural analyst I also have access to finite element code so I fully analyzed the lower A designs (I have 5 of 'em now hahaha) to make sure they are structurally sufficient. If I get off track in a big way I will likely bend them, but that you can't design for without having a 10lb A arm. These are just over 5 lbs per the modeling software. |
byndbad914 |
May 8 2010, 10:53 PM
been a couple weeks with no updates... got the rear lower As all tacked into place and tacked the front left corner in, then in my usual fashion, decided to change my mind and called the water jet company to have some new lower A brackets made for the front that are longer. Gonna go ahead and remove more of the scrub and just cough up the extra cash and PITA of new wheel halves... getting them to not leak has been a bit of a challenge so any good ideas for sealant, etc feel free to let me know (IMG:style_emoticons/default/smile.gif)
Called Kodiak wheels a couple times now to work on getting new front wheel halves and those jackasses are the worst customer service ever other than Kanna Motorsports, still haven't heard back from them tho' I am assured someone will call me back (IMG:style_emoticons/default/mad.gif) They sucked ass on their customer service when I ordered them (they were good 'til they got me sucked into ever extending lead times and 6-8 weeks became 17 then made me deal with the FedEx claim when they damaged an outer) and this is really what I sadly expected. They must be busy Fing up Fikse since they took them over. Anyway, maybe one of these days I can get some new wheel halves on the way - I am assuming it will take 17 weeks to get 'em as that is what screwed up my initial order so I sorta wanna get that ball rolling. Been talking to Penske and am pretty much set on getting a full set of their DA 8300s, just needed to predict what my spring rates will be with this setup (calculated suspension frequencies base on new motion ratios) so will be ordering hopefully this week. These seem to be the sh!t and unlike Kodiak the guy I have been talking to at Penske has been pretty cool and decent to work with. Of all the upgrades I could make, I know the shocks are gonna be a great one. http://www.penskeshocks.com/Sports_Car-For...8300_Series.php hoping tomorrow to have my machinist buddy call me with more stuff done to get the rear uprights together and get the rear done, but we'll see how far he got today. Spent today stripping turbo axles down, putting inner CVs on both ends with Swepco 101 grease. Will be nice having both ends rebuild-able now with my custom stub axles setup. So while I have been slow on updates, been busy working on it. edit - and watching Toto on TV... holy crap that is an awesome group of musicians. Being a teen in the 80s I tended to like a couple of their songs, but gooood lawd I have played guitar for 22 years and can say their guitarist is awesome and having started learning drums this year, drummer is phenomenal too. Funny as my electronic drum set I bought used has a user programmed set that is the Toto drummer (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:09 AM |
