> 4 lug - anyone install studs and nuts, bolts suck : )
jimkelly
post May 8 2010, 06:10 AM
Delaware USA
i'd prefer studs so i can just thrown the wheel/tire onto the rotor without the whole orientation dance of hands a feet : )
Rav914
post May 10 2010, 01:44 PM
All-weather fan
http://www.race-studs.com/servlet/Categories
For the 2.0 liter Fuchs, would I use the Porsche nuts or the spherical VW/Audi nuts?
jimkelly
post May 12 2010, 07:23 AM
Delaware USA
rav - seems like i should have ordered the porsche nuts
the lug is about 24mm wide and the nut is about 25mm wide
the lug seats perfectly into my 4 lug fuch but the nut does not.
according to the website - the porsche nut has a R14 ball seat ??
the one i ordered has a R13 ball seat ??
jim
QUOTE(Rav914 @ May 10 2010, 12:44 PM) *
jimkelly   4 lug - anyone install studs and nuts   May 8 2010, 06:10 AM
914Sixer   I have been considering doing it and using 911 all...   May 8 2010, 06:21 AM
jimkelly   for 4 lug fuchs, i would need something like this....   May 8 2010, 06:43 AM
benalishhero   I made my own studs on my car with A/M nuts. They ...   May 8 2010, 08:04 AM
DanT   Check here....studs and nuts Several styles to cho...   May 8 2010, 09:18 AM
McMark   Uh-oh, here comes the thread in stud debate. :hid...   May 8 2010, 09:21 AM
DanT   Uh-oh, here comes the thread in stud debate. :hi...   May 8 2010, 09:31 AM
jimkelly   :popcorn: Uh-oh, here comes the thread in stud ...   May 8 2010, 12:44 PM
DanT   they work quite well when you choose good quality ...   May 8 2010, 09:44 AM
ChrisNPDrider   I've used racing studs for 2+ years, they have...   May 8 2010, 09:44 AM
root   Seems like alot of effort just to avoid the 's...   May 8 2010, 10:00 AM
realred914   how oft do you change wheels? is it realy wroth t...   May 8 2010, 10:28 AM
DanT   If you change wheels with a different seat, you ca...   May 8 2010, 11:04 AM
Bartlett 914   I use wheel hangers when changing my wheels. Makes...   May 8 2010, 11:50 AM
Racer Chris   If you have hubcentric wheels here's another s...   May 8 2010, 12:05 PM
Tom_T   i'd prefer studs so i can just thrown the whe...   May 8 2010, 01:37 PM
Chris Hamilton   studs: http://www.hamiltonracing.net/photos/red91...   May 8 2010, 04:01 PM
charliew   Chris are those rings a press fit in the rotor or ...   May 8 2010, 05:06 PM
Racer Chris   Chris are those rings a press fit in the rotor or...   May 8 2010, 06:07 PM
burton73   Chris are those rings a press fit in the rotor o...   May 8 2010, 07:39 PM
Racer Chris   [quote name='Racer Chris' post='1315597' date='Ma...   May 8 2010, 10:11 PM
JimN73   I was going to use studs. I found that using 50 m...   May 8 2010, 05:06 PM
scotty b   Chuck Norris just tells his wheels to stay on the ...   May 8 2010, 05:10 PM
underthetire   B)-->
QUOTE(scotty b @ M...   May 10 2010, 03:42 PM
jaxdream   Are 2 L fuchs hubcentric ??? :confused: Jack / j...   May 9 2010, 08:02 AM
jimkelly   http://www.race-studs.com/servlet/Categories * co...   May 9 2010, 08:59 PM
Elliot Cannon   http://www.race-studs.com/servlet/Categories see...   May 9 2010, 09:17 PM
DanT   I believe you need 14x1.5 :) when I installed min...   May 9 2010, 09:11 PM
DanT   torque and loctite :D   May 9 2010, 09:26 PM
Rav914   http://www.race-studs.com/servlet/Categories For ...   May 10 2010, 01:44 PM
jimkelly   rav - seems like i should have ordered the porsche...   May 12 2010, 07:23 AM
jimkelly   i sure hope it does not matter as i ordered the bl...   May 10 2010, 03:07 PM
DanT   those should work fine Jim....Spherical/ball seat ...   May 10 2010, 03:22 PM
jimkelly   that said - i can not wait to get these studs inst...   May 12 2010, 07:30 AM
jimkelly   R13 seat ball   May 12 2010, 08:07 AM
Rav914   Thanks for the info. I ordered the Porsche nuts, ...   May 12 2010, 10:04 AM
9146986   Just to be sure I'd take a Sharpie and totally...   May 12 2010, 10:07 AM
ChrisNPDrider   :agree: Ideally, the stud length/wheel/spacer com...   May 12 2010, 10:39 AM
jimkelly   regarding threads showing past nut - the pic aboev...   May 12 2010, 11:36 AM
jimkelly   ok - i installed one set of studs and lugs - i bla...   May 12 2010, 12:35 PM
9146986   I don't know Jim, that doesn't look right ...   May 12 2010, 01:20 PM
jimkelly   yeah - i should have commented. it does not look ...   May 12 2010, 03:30 PM
jimkelly   rcvd the porsche nuts today. seems like 65mm stud...   May 14 2010, 08:02 PM
Racer Chris   rcvd the porsche nuts today. seems like 65mm stu...   May 14 2010, 11:21 PM
DanT   did you use any spacers Jim? I thought that there ...   May 14 2010, 08:04 PM
jimkelly   i did not use any spacers.   May 14 2010, 08:07 PM
jimkelly   thanks - while all 16 studs protrude beyond the nu...   May 15 2010, 05:42 AM
Racer Chris   thanks - while all 16 studs protrude beyond the n...   May 15 2010, 08:33 AM
charliew   If it was mine I would get longer studs on the rea...   May 15 2010, 09:53 AM
DanT   so what did you finally decided to do Jim? :)   May 23 2010, 09:58 PM
jimkelly   i will stick with the 65mm studs all around and po...   May 24 2010, 10:27 AM
yeahmag   I'm using the same studs with a bit of blue lo...   May 24 2010, 10:56 AM
DanT   I will probably go with the 80mm studs since I wil...   May 24 2010, 11:26 AM
Sleepin   DAPO's around the world agree: Screw in studs ...   May 24 2010, 01:56 PM
DanT   that is a step down stud..... <_< absolutel...   May 24 2010, 04:54 PM
- Lo-Fi Version Time is now: 15th June 2026 - 06:54 AM
