| woodgeek |
May 12 2010, 07:43 AM
Newbie ![]() Group: Members Posts: 4 Joined: 7-July 09 From: Germantown, MD Member No.: 10,544 Region Association: MidAtlantic Region |
Do all 914 rear calipers use the funky RIBE fasteners? I'm spending this coming weekend working on my 1975 1.8 and I'm trying to gather up / order all of the tools and supplies I'll need.
My 914 runs but idles rough and the brakes are frozen. So, I've ordered / rounded up the following:
The only thing I'm uncertain about are the RIBE fasteners on the rear calipers. I've read that the RIBE fasteners are used on the early 914's -- are they only on the early ones? Mine is a '75; will it have those fasteners? The reason I'm asking is the car is 200 miles away so I can't walk out and check. (IMG:style_emoticons/default/biggrin.gif) I'm bringing my torx bits and a propane torch just in case. I've heard that using the torx bits on ribe fasteners can be hit or miss. thanks, dave |
| Eric_Shea |
May 12 2010, 09:20 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE they combined regular hex and those randomly (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif)Yours have the standard 11mm hex. They are made by both Ribe and Verbus but, you won't have the proprietary head design to deal with. I believe the 45mm are Verbus and your 50mm are Ribe. That said, someone may have retrofitted an older caliper on the car... I've seen it all (almost). That being the case... Torx "can" work but in limited capacity. Do not try to tension with a torx. Only use them to hold the fastener head in place and, do all you can to minimize the force put on them (torch, penetrating oil, preload, etc.) (IMG:style_emoticons/default/welcome.png) |
| woodgeek |
May 12 2010, 09:31 AM
QUOTE they combined regular hex and those randomly (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif)Yours have the standard 11mm hex. They are made by both Ribe and Verbus but, you won't have the proprietary head design to deal with. I believe the 45mm are Verbus and your 50mm are Ribe. That said, someone may have retrofitted an older caliper on the car... I've seen it all (almost). That being the case... Torx "can" work but in limited capacity. Do not try to tension with a torx. Only use them to hold the fastener head in place and, do all you can to minimize the force put on them (torch, penetrating oil, preload, etc.) (IMG:style_emoticons/default/welcome.png) Thanks guys and thanks for the welcome! (IMG:style_emoticons/default/biggrin.gif) I'll take some pics this weekend. |
woodgeek rear caliper RIBE fasteners May 12 2010, 07:43 AM
dr914@autoatlanta.com No they combined regular hex and those randomly.
... May 12 2010, 09:17 AM
type47 Any particular reason you are going to separate th... May 12 2010, 10:29 AM
woodgeek
Any particular reason you are going to separate t... May 12 2010, 10:35 AM
sean_v8_914 what problems are created from caliper separation? May 12 2010, 12:22 PM
Eric_Shea Legal problems, which is how the Internet myth got... May 12 2010, 01:56 PM
sean_v8_914 every time I see Eric post I wonder: why am i stil... May 12 2010, 02:42 PM
sean_v8_914 Im gonna go weld something now May 12 2010, 02:43 PM
Eric_Shea You send me all your calipers... I'll send you... May 12 2010, 02:55 PM
sean_v8_914 deal! i'de rather dodge slag for 2 hours t... May 17 2010, 10:52 AM
Eric_Shea
Is it a really handsome guy? Yes! :D May 17 2010, 11:31 AM
woodgeek Thanks for the tips guys. Had a great weekend wor... May 18 2010, 09:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th July 2026 - 06:57 PM |
