| jimkelly |
May 8 2010, 06:10 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i'd prefer studs so i can just thrown the wheel/tire onto the rotor without the whole orientation dance of hands a feet : )
| IronHillRestorations |
May 12 2010, 10:07 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,945 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Just to be sure I'd take a Sharpie and totally black out the seat on the wheel, and then torque a nut on and see where you are getting contact. If it's a broad area you are OK, but if it shows a thin line it's a no workie.
FWIW, they do look correct from the pic. |
jimkelly 4 lug - anyone install studs and nuts May 8 2010, 06:10 AM
914Sixer I have been considering doing it and using 911 all... May 8 2010, 06:21 AM
jimkelly for 4 lug fuchs, i would need something like this.... May 8 2010, 06:43 AM
benalishhero I made my own studs on my car with A/M nuts. They ... May 8 2010, 08:04 AM
DanT Check here....studs and nuts
Several styles to cho... May 8 2010, 09:18 AM
McMark Uh-oh, here comes the thread in stud debate. :hid... May 8 2010, 09:21 AM
DanT
Uh-oh, here comes the thread in stud debate. :hi... May 8 2010, 09:31 AM
jimkelly :popcorn:
Uh-oh, here comes the thread in stud ... May 8 2010, 12:44 PM
DanT they work quite well when you choose good quality ... May 8 2010, 09:44 AM
ChrisNPDrider I've used racing studs for 2+ years, they have... May 8 2010, 09:44 AM
root Seems like alot of effort just to avoid the 's... May 8 2010, 10:00 AM
realred914 how oft do you change wheels? is it realy wroth t... May 8 2010, 10:28 AM
DanT If you change wheels with a different seat, you ca... May 8 2010, 11:04 AM
Bartlett 914 I use wheel hangers when changing my wheels. Makes... May 8 2010, 11:50 AM
Racer Chris If you have hubcentric wheels here's another s... May 8 2010, 12:05 PM
Tom_T
i'd prefer studs so i can just thrown the whe... May 8 2010, 01:37 PM
Chris Hamilton studs:
http://www.hamiltonracing.net/photos/red91... May 8 2010, 04:01 PM
charliew Chris are those rings a press fit in the rotor or ... May 8 2010, 05:06 PM
Racer Chris
Chris are those rings a press fit in the rotor or... May 8 2010, 06:07 PM
burton73
Chris are those rings a press fit in the rotor o... May 8 2010, 07:39 PM
Racer Chris
[quote name='Racer Chris' post='1315597' date='Ma... May 8 2010, 10:11 PM
JimN73 I was going to use studs. I found that using 50 m... May 8 2010, 05:06 PM
scotty b Chuck Norris just tells his wheels to stay on the ... May 8 2010, 05:10 PM
underthetire B)-->
jaxdream Are 2 L fuchs hubcentric ??? :confused:
Jack / j... May 9 2010, 08:02 AM
jimkelly http://www.race-studs.com/servlet/Categories
* co... May 9 2010, 08:59 PM
Elliot Cannon
see... May 9 2010, 09:17 PM
DanT I believe you need 14x1.5 :)
when I installed min... May 9 2010, 09:11 PM
DanT torque and loctite :D May 9 2010, 09:26 PM
Rav914 http://www.race-studs.com/servlet/Categories
For ... May 10 2010, 01:44 PM
jimkelly rav - seems like i should have ordered the porsche... May 12 2010, 07:23 AM
jimkelly i sure hope it does not matter as i ordered the bl... May 10 2010, 03:07 PM
DanT those should work fine Jim....Spherical/ball seat ... May 10 2010, 03:22 PM
jimkelly that said - i can not wait to get these studs inst... May 12 2010, 07:30 AM
jimkelly R13 seat ball May 12 2010, 08:07 AM
Rav914 Thanks for the info. I ordered the Porsche nuts, ... May 12 2010, 10:04 AM
ChrisNPDrider :agree:
Ideally, the stud length/wheel/spacer com... May 12 2010, 10:39 AM
jimkelly regarding threads showing past nut - the pic aboev... May 12 2010, 11:36 AM
jimkelly ok - i installed one set of studs and lugs - i bla... May 12 2010, 12:35 PM
9146986 I don't know Jim, that doesn't look right ... May 12 2010, 01:20 PM
jimkelly yeah - i should have commented.
it does not look ... May 12 2010, 03:30 PM
jimkelly rcvd the porsche nuts today.
seems like 65mm stud... May 14 2010, 08:02 PM
Racer Chris
seems like 65mm stu... May 14 2010, 11:21 PM
DanT did you use any spacers Jim?
I thought that there ... May 14 2010, 08:04 PM
jimkelly i did not use any spacers. May 14 2010, 08:07 PM
jimkelly thanks - while all 16 studs protrude beyond the nu... May 15 2010, 05:42 AM
Racer Chris
thanks - while all 16 studs protrude beyond the n... May 15 2010, 08:33 AM
charliew If it was mine I would get longer studs on the rea... May 15 2010, 09:53 AM
DanT so what did you finally decided to do Jim? :) May 23 2010, 09:58 PM
jimkelly i will stick with the 65mm studs all around and po... May 24 2010, 10:27 AM
yeahmag I'm using the same studs with a bit of blue lo... May 24 2010, 10:56 AM
DanT I will probably go with the 80mm studs since I wil... May 24 2010, 11:26 AM
Sleepin DAPO's around the world agree: Screw in studs ... May 24 2010, 01:56 PM
DanT that is a step down stud..... <_<
absolutel... May 24 2010, 04:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 06:54 AM |
