> 1973 2.0L CHT, does it exist?
rwilner
post May 13 2010, 02:09 PM
No Ghosts in the Machine
I fear mine may need replacing. Even if it doesn't now, I'm sure it will SOME day.
My search has revealed that I am more likely to find a leprechaun than one of these elusive parts.
Do they exist? Is anyone making them?
George?? (IMG:style_emoticons/default/sad.gif)
Tom_T
post May 13 2010, 04:23 PM
TMI....
QUOTE(rwilner @ May 13 2010, 01:09 PM) *
(IMG:style_emoticons/default/shades.gif) BTW - Rich, you've been a member here for almost 2 months now & owned your 73 2.0 914 for about what? - 4 weeks now - Geez young man, shouldn't you have posted your "new" 914's VIN & other info with pix on here by now buddy!!?? (IMG:style_emoticons/default/biggrin.gif)
... get with the program man! (IMG:style_emoticons/default/type.gif)
We're all waiting to see something other than your I found my 914, I picked up my 914, I'm towing my 914 backwards posts of it on a trailer! ... we all know it's been running around the block at least by now, even if illegally!!! (IMG:style_emoticons/default/lol-2.gif)
No seriously though - really - try to get all of your VIN, engine, chassis, paint code nos. in there with a description & pix of your ride & story, cuz it helps everyone track the 914s. I was admonished to get my butt in gear to add the donor shell by another member for the same reason, so I'm passing it along! (IMG:style_emoticons/default/biggrin.gif)
rwilner
post May 13 2010, 07:44 PM
QUOTE(Tom_T @ May 13 2010, 06:23 PM) *
Ha!
I promise I will do this weekend. I would have done it tonight...
but....
I just got back from driving it for 3 hrs! (IMG:style_emoticons/default/driving.gif)
top off on a cool late spring night. is there anything better??
r_towle
post May 13 2010, 09:00 PM
Custom Member
QUOTE(rwilner @ May 13 2010, 09:44 PM) *
Ha!
but....
Get the timing set right.
When cold, turn the key on and off three times.
Fourth time, start the car.
If that works, you might want to change fuel filter, fuel tank sock and check all your fuel lines for leaks....including the cold start injector.
My car, same climate starts right up with NO cold start injector, NO AAR valve and NO decel valve.
Start like a champ running points and condensor.
My cold start injector was leaking and stuck open partially.
When cold it flooded the motor.
When parked it leat all the pressure out of the system.
I routed around it....it starts fine.
Rich
rwilner
post May 14 2010, 06:34 AM
QUOTE(r_towle @ May 13 2010, 11:00 PM) *
Rich
I do this as it's actually in George's tech tips 700 book. Makes no difference -- takes 8 to 10s to catch, only when cold.
I made a video of it last night to post here so you guys can see first hand what's happening, i'll post that tonight.
Hopefully setting the timing right this weekend will resolve the issue.
(Hopefully there's a timing mark on my fan!!)
rwilner   1973 2.0L CHT   May 13 2010, 02:09 PM
benalishhero   0280130012 ?   May 13 2010, 02:17 PM
rmital   I fear mine may need replacing. Even if it doesn...   May 13 2010, 02:26 PM
rmital   I fear mine may need replacing. Even if it does...   May 13 2010, 03:01 PM
dr914@autoatlanta.com   [quote name='rmital' post='1317950' date='May 13 ...   May 13 2010, 03:19 PM
rwilner   [quote name='dr914@autoatlanta.com' date=...   May 13 2010, 04:10 PM
rwilner   [quote name='rmital' post='1317950' date='May 13 ...   May 13 2010, 04:08 PM
Tom_T   [quote name='rmital' post='1317965' date='May 13 ...   May 13 2010, 04:51 PM
914Sixer   012 or 017. The only difference is in the length ...   May 13 2010, 02:50 PM
dr914@autoatlanta.com   I fear mine may need replacing. Even if it doesn...   May 13 2010, 02:51 PM
SLITS   George, I believe you would know it as Temperature...   May 13 2010, 02:54 PM
Tom_T   I fear mine may need replacing. Even if it doesn...   May 13 2010, 04:14 PM
Tom_T   I fear mine may need replacing. Even if it doesn...   May 13 2010, 04:23 PM
rwilner   :shades2: BTW - Rich, you've been a member ...   May 13 2010, 07:44 PM
r_towle   :shades2: BTW - Rich, you've been a member...   May 13 2010, 09:00 PM
rwilner   When cold, turn the key on and off three times. F...   May 14 2010, 06:34 AM
Tom_T   I just got back from driving it for 3 hrs! ...   May 14 2010, 12:46 AM
rwilner   Don't tell your wife or S.O., but 914's a...   May 14 2010, 06:36 AM
Tom_T   Don't tell your wife or S.O., but 914's ...   May 14 2010, 12:30 PM
scrz914   Okay, I've got a used 017 and a brand new 012 ...   May 13 2010, 10:45 PM
Tom_T   Okay, I've got a used 017 and a brand new 012...   May 14 2010, 12:51 AM
kkid   Okay, I've got a used 017 and a brand new 012...   May 14 2010, 07:58 AM
914Sixer   Here are pictures of NOS of the head temp sensor 0...   May 15 2010, 07:16 AM
- Lo-Fi Version Time is now: 15th July 2025 - 03:26 AM
