> 4 lug - anyone install studs and nuts, bolts suck : )
jimkelly
post May 8 2010, 06:10 AM
Delaware USA
i'd prefer studs so i can just thrown the wheel/tire onto the rotor without the whole orientation dance of hands a feet : )
jimkelly
post May 15 2010, 05:42 AM
Delaware USA
thanks - while all 16 studs protrude beyond the nut - only on the front is there any thread on the stud showing. on the rear the nut has a thread or two not grabbin anything because the very end of the stud is not threaded.
now i got the tri color bling going on - silver gold and black, bling bling : )
gotta get me a torque wrench.
ChrisFoley
post May 15 2010, 08:33 AM
I am Tangerine Racing
QUOTE(jimkelly @ May 15 2010, 07:42 AM) *
I went back and looked at your picture of a stud before you installed it to see what you mean.
A general rule of thumb is the length of thread engagement of the nut should be greater than the diameter of the bolt. So on 14x1.5 if you have at least 10 threads working, thats 15mm of thread engagement.
With the proper torque you'll be fine.
jimkelly   4 lug - anyone install studs and nuts   May 8 2010, 06:10 AM
914Sixer   I have been considering doing it and using 911 all...   May 8 2010, 06:21 AM
jimkelly   for 4 lug fuchs, i would need something like this....   May 8 2010, 06:43 AM
benalishhero   I made my own studs on my car with A/M nuts. They ...   May 8 2010, 08:04 AM
DanT   Check here....studs and nuts Several styles to cho...   May 8 2010, 09:18 AM
McMark   Uh-oh, here comes the thread in stud debate. :hid...   May 8 2010, 09:21 AM
DanT   Uh-oh, here comes the thread in stud debate. :hi...   May 8 2010, 09:31 AM
jimkelly   :popcorn: Uh-oh, here comes the thread in stud ...   May 8 2010, 12:44 PM
DanT   they work quite well when you choose good quality ...   May 8 2010, 09:44 AM
ChrisNPDrider   I've used racing studs for 2+ years, they have...   May 8 2010, 09:44 AM
root   Seems like alot of effort just to avoid the 's...   May 8 2010, 10:00 AM
realred914   how oft do you change wheels? is it realy wroth t...   May 8 2010, 10:28 AM
DanT   If you change wheels with a different seat, you ca...   May 8 2010, 11:04 AM
Bartlett 914   I use wheel hangers when changing my wheels. Makes...   May 8 2010, 11:50 AM
Racer Chris   If you have hubcentric wheels here's another s...   May 8 2010, 12:05 PM
Tom_T   i'd prefer studs so i can just thrown the whe...   May 8 2010, 01:37 PM
Chris Hamilton   studs: http://www.hamiltonracing.net/photos/red91...   May 8 2010, 04:01 PM
charliew   Chris are those rings a press fit in the rotor or ...   May 8 2010, 05:06 PM
Racer Chris   Chris are those rings a press fit in the rotor or...   May 8 2010, 06:07 PM
burton73   Chris are those rings a press fit in the rotor o...   May 8 2010, 07:39 PM
Racer Chris   [quote name='Racer Chris' post='1315597' date='Ma...   May 8 2010, 10:11 PM
JimN73   I was going to use studs. I found that using 50 m...   May 8 2010, 05:06 PM
scotty b   Chuck Norris just tells his wheels to stay on the ...   May 8 2010, 05:10 PM
underthetire   B)-->
QUOTE(scotty b @ M...   May 10 2010, 03:42 PM
jaxdream   Are 2 L fuchs hubcentric ??? :confused: Jack / j...   May 9 2010, 08:02 AM
jimkelly   http://www.race-studs.com/servlet/Categories * co...   May 9 2010, 08:59 PM
Elliot Cannon   http://www.race-studs.com/servlet/Categories see...   May 9 2010, 09:17 PM
DanT   I believe you need 14x1.5 :) when I installed min...   May 9 2010, 09:11 PM
DanT   torque and loctite :D   May 9 2010, 09:26 PM
Rav914   http://www.race-studs.com/servlet/Categories For ...   May 10 2010, 01:44 PM
jimkelly   rav - seems like i should have ordered the porsche...   May 12 2010, 07:23 AM
jimkelly   i sure hope it does not matter as i ordered the bl...   May 10 2010, 03:07 PM
DanT   those should work fine Jim....Spherical/ball seat ...   May 10 2010, 03:22 PM
jimkelly   that said - i can not wait to get these studs inst...   May 12 2010, 07:30 AM
jimkelly   R13 seat ball   May 12 2010, 08:07 AM
Rav914   Thanks for the info. I ordered the Porsche nuts, ...   May 12 2010, 10:04 AM
9146986   Just to be sure I'd take a Sharpie and totally...   May 12 2010, 10:07 AM
ChrisNPDrider   :agree: Ideally, the stud length/wheel/spacer com...   May 12 2010, 10:39 AM
jimkelly   regarding threads showing past nut - the pic aboev...   May 12 2010, 11:36 AM
jimkelly   ok - i installed one set of studs and lugs - i bla...   May 12 2010, 12:35 PM
9146986   I don't know Jim, that doesn't look right ...   May 12 2010, 01:20 PM
jimkelly   yeah - i should have commented. it does not look ...   May 12 2010, 03:30 PM
jimkelly   rcvd the porsche nuts today. seems like 65mm stud...   May 14 2010, 08:02 PM
Racer Chris   rcvd the porsche nuts today. seems like 65mm stu...   May 14 2010, 11:21 PM
DanT   did you use any spacers Jim? I thought that there ...   May 14 2010, 08:04 PM
jimkelly   i did not use any spacers.   May 14 2010, 08:07 PM
jimkelly   thanks - while all 16 studs protrude beyond the nu...   May 15 2010, 05:42 AM
Racer Chris   thanks - while all 16 studs protrude beyond the n...   May 15 2010, 08:33 AM
charliew   If it was mine I would get longer studs on the rea...   May 15 2010, 09:53 AM
DanT   so what did you finally decided to do Jim? :)   May 23 2010, 09:58 PM
jimkelly   i will stick with the 65mm studs all around and po...   May 24 2010, 10:27 AM
yeahmag   I'm using the same studs with a bit of blue lo...   May 24 2010, 10:56 AM
DanT   I will probably go with the 80mm studs since I wil...   May 24 2010, 11:26 AM
Sleepin   DAPO's around the world agree: Screw in studs ...   May 24 2010, 01:56 PM
DanT   that is a step down stud..... <_< absolutel...   May 24 2010, 04:54 PM
- Lo-Fi Version Time is now: 15th June 2026 - 06:54 AM
