| EJP914 |
May 15 2010, 04:35 PM
Member ![]() ![]() Group: Members Posts: 296 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Is there any relationship between idle speed and gear grinding when going into 1st and Reverse? My car idles a little over 1000 rpm and it is now tough getting into 1st when stoppoing at intersection. Makes a hell of a racket.
It never did this before it was put away last yr. Can this grinding be adjusted out by the clutch adjustment? Clutch pedal is pretty soft and mushy. It engages right off the floor. How do you know if clutch tube is broken? Car shifts ok into 2-5 and back down. Is this a synchro problem? Sorry for alll the questions. Just trying to figure out what to look at first. Figured someone out there has run into this already. Thanks |
| Dave_Darling |
May 15 2010, 06:25 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,353 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The higher idle doesn't do your transmission any favors, but the symptoms point to a clutch that is out of adjustment. And possibly in need of replacement. And/or possibly a clutch tube in need of help.
Look through the holes in the top of the center tunnel (e.g., where the gear shift lever goes through, and where the heater lever was before you removed it to be able to see). Can you see the clutch tube moving from side to side when you push the pedal down? --DD |
| jt914-6 |
May 15 2010, 06:33 PM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
The higher idle doesn't do your transmission any favors, but the symptoms point to a clutch that is out of adjustment. And possibly in need of replacement. And/or possibly a clutch tube in need of help. Look through the holes in the top of the center tunnel (e.g., where the gear shift lever goes through, and where the heater lever was before you removed it to be able to see). Can you see the clutch tube moving from side to side when you push the pedal down? --DD (IMG:style_emoticons/default/agree.gif) I have always found that if you put your car in first gear as you come to a stop (still rolling slowly) it is easier on the tranny than putting it into first gear from a dead stop. Try it and see what you think.... |
EJP914 Gear grind into 1st & R May 15 2010, 04:35 PM
Millerwelds Adjust the clutch. It sounds like the linkage is ... May 15 2010, 04:39 PM
Dr Evil Clutch drag due to any of the aforementioned issue... May 16 2010, 12:39 AM
EJP914 In response to Dr Evil question, I'm not sure ... May 17 2010, 07:57 PM
mtndawg I'm inteterested in comments about this too. I... May 18 2010, 01:55 PM
underthetire
I'm inteterested in comments about this too. ... May 18 2010, 02:35 PM
Dr Evil At the floor = inadequate disengagement. This = dr... May 18 2010, 09:36 PM
914 Guys,
In my four I had the cable replaced... May 19 2010, 07:17 AM
Dr Evil Yes, Terry is too long, but easily remedied by ins... May 19 2010, 12:46 PM
914
Yes, Terry is too long, but easily remedied by in... May 19 2010, 02:01 PM
Dr Evil When you get to 4+ washers, it is time to change t... May 19 2010, 02:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th July 2026 - 11:04 AM |
