| EJP914 |
May 15 2010, 04:35 PM
Member ![]() ![]() Group: Members Posts: 296 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Is there any relationship between idle speed and gear grinding when going into 1st and Reverse? My car idles a little over 1000 rpm and it is now tough getting into 1st when stoppoing at intersection. Makes a hell of a racket.
It never did this before it was put away last yr. Can this grinding be adjusted out by the clutch adjustment? Clutch pedal is pretty soft and mushy. It engages right off the floor. How do you know if clutch tube is broken? Car shifts ok into 2-5 and back down. Is this a synchro problem? Sorry for alll the questions. Just trying to figure out what to look at first. Figured someone out there has run into this already. Thanks |
| Dr Evil |
May 16 2010, 12:39 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Clutch drag due to any of the aforementioned issues. Where in the pushing in of your clutch pedal does the clutch disengage?
EJP914 Gear grind into 1st & R May 15 2010, 04:35 PM
Millerwelds Adjust the clutch. It sounds like the linkage is ... May 15 2010, 04:39 PM
Dave_Darling The higher idle doesn't do your transmission a... May 15 2010, 06:25 PM
jt914-6
The higher idle doesn't do your transmission ... May 15 2010, 06:33 PM
EJP914 In response to Dr Evil question, I'm not sure ... May 17 2010, 07:57 PM
mtndawg I'm inteterested in comments about this too. I... May 18 2010, 01:55 PM
underthetire
I'm inteterested in comments about this too. ... May 18 2010, 02:35 PM
Dr Evil At the floor = inadequate disengagement. This = dr... May 18 2010, 09:36 PM
914 Guys,
In my four I had the cable replaced... May 19 2010, 07:17 AM
Dr Evil Yes, Terry is too long, but easily remedied by ins... May 19 2010, 12:46 PM
914
Yes, Terry is too long, but easily remedied by in... May 19 2010, 02:01 PM
Dr Evil When you get to 4+ washers, it is time to change t... May 19 2010, 02:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th July 2026 - 10:13 AM |
