| poorsche914 |
Jul 3 2009, 01:13 PM
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,146 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I removed the smog rails from my 2.0, blocked the air pipes with caps, and reattached all the vacuum lines - used the diagram for '73-'74 2.0 that is available here or on PP or ???. Anyway, car idles fine but loses power around 3k and backfires on decel. I do have a bit of an exhaust leak at the heads (new gaskets ordered)
Just wanted to verify that I have the vac lines hooked up correctly. Once I know that I plan to get all new lines as well as get rid of any exhaust leaks. Click on picture for larger image. (IMG:http://www.volksbraggin.com/porsche/vacLines_1.jpg) TIA. |
| Dave_Darling |
May 16 2010, 11:56 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
One thing to note: Since that diagram was made, we have come to the conclusion that the larger hoses (colored blue on that diagram) to the Decel Valve need to be swapped; the one plugged into the side of the DV should go to the air cleaner, and the one plugged into the back of the DV to the manifold.
--DD |
poorsche914 Vacuum Line Help Please - desmogged '75 2.0 Jul 3 2009, 01:13 PM
mipstien as i now have the car i am interested in this ^^^ May 16 2010, 07:11 AM
detoxcowboy RE: Vacuum Line Help Please - desmogged '75 2.0 May 16 2010, 07:20 AM
mipstien thank you! May 16 2010, 07:28 AM
mipstien any chance someone could take a top down picture o... May 16 2010, 12:08 PM
poorsche914 Try that swap Dave_Darling suggested because I kno... May 16 2010, 12:12 PM
mipstien you had them hooked up correctly. as in the way he... May 16 2010, 12:23 PM
Jeff Bowlsby :D May 16 2010, 12:46 PM
mipstien awesome, ill print this out later and have a go at... May 16 2010, 12:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 03:18 AM |
