| poorsche914 |
May 16 2010, 08:06 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,163 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Question for you gurus out there...
My recently purchased LE has the "lip" running across the front edge that I thought was only on the '75-'76 to help hold the big bumpers. Also, as you can see in one of the pics, the hole for the late model bumper shocks is there but so are the early bumper mount holes (of course, since that is the bumper that is on it) Did they set up the front for both style of bumpers as a transition or ??? The bumper top was not covering the "lip"... should I remove that piece? Thanks. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062011.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062012.2.jpg) |
| dr914@autoatlanta.com |
May 17 2010, 08:43 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,245 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The front panel HAS been replaced before. You MUST cut off that extra lip for the bumper top seal to fit properly. Also holes must be drilled and nut cages installed to properly mount the horns and driving lights.
For concours perfection and value, you MUST replace this front panel with the earlier style one cut from another car as the early front panel has long been discontinued. LEs are so valuable these days that one should NEVER go the wrong way when restoring. Question for you gurus out there... My recently purchased LE has the "lip" running across the front edge that I thought was only on the '75-'76 to help hold the big bumpers. Also, as you can see in one of the pics, the hole for the late model bumper shocks is there but so are the early bumper mount holes (of course, since that is the bumper that is on it) Did they set up the front for both style of bumpers as a transition or ??? The bumper top was not covering the "lip"... should I remove that piece? Thanks. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062011.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062012.2.jpg) |
| poorsche914 |
May 17 2010, 08:59 AM
The front panel HAS been replaced before. You MUST cut off that extra lip for the bumper top seal to fit properly. Also holes must be drilled and nut cages installed to properly mount the horns and driving lights. For concours perfection and value, you MUST replace this front panel with the earlier style one cut from another car as the early front panel has long been discontinued. LEs are so valuable these days that one should NEVER go the wrong way when restoring. Thank you for your input, George. I thought the lip would have to be removed for proper fitment of the early style bumper. That is what I will do for the short term and in the future replace the entire front panel. I haven't had a chance to look closely to see if I can spot repair work. It sure isn't obvious, though. |
poorsche914 Mounting area for both early and late bumpers? May 16 2010, 08:06 PM
jmill Leave the lip. You need it to hold in the hood se... May 16 2010, 08:20 PM
Root_Werks
Leave the lip. You need it to hold in the hood s... May 18 2010, 10:26 AM
70_914 That foglight mounting system is interesting. :c... May 16 2010, 09:47 PM
poorsche914 Yes, I noticed that too but the rains came and I d... May 16 2010, 10:32 PM
Dave_Darling I'm guessing the car was hit in the front, and... May 16 2010, 10:31 PM
Tom_T
http://www.914world.com/bbs2/uploads_offsite/www.... May 17 2010, 01:26 AM
r_towle Show a top and bottom pic of the serial number on ... May 17 2010, 08:50 AM
poorsche914
Show a top and bottom pic of the serial number on... May 17 2010, 09:00 AM
r_towle looks stock.
If you look behind the headlights, i... May 17 2010, 09:03 AM
poorsche914
looks stock.
If you look behind the headlights, ... May 17 2010, 09:40 AM
jmill That's been hit and repaired. Here's pict... May 17 2010, 05:56 PM
poorsche914
That's been hit and repaired. ...
And upon ... May 17 2010, 06:38 PM
jmill
Looks like a relatively easy repair for someone w... May 17 2010, 06:02 PM
r_towle The seam sealer is the give away...in the first tw... May 17 2010, 06:36 PM
jmill
And upon further inspection, the driver quarter p... May 17 2010, 07:57 PM
poorsche914 I will take pics tomorrow. Passenger fender undern... May 17 2010, 09:40 PM
realred914 :sick: :trophy: :smash: :welder:
I will take p... May 18 2010, 09:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th September 2026 - 06:23 PM |
