| poorsche914 |
May 16 2010, 08:06 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,163 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Question for you gurus out there...
My recently purchased LE has the "lip" running across the front edge that I thought was only on the '75-'76 to help hold the big bumpers. Also, as you can see in one of the pics, the hole for the late model bumper shocks is there but so are the early bumper mount holes (of course, since that is the bumper that is on it) Did they set up the front for both style of bumpers as a transition or ??? The bumper top was not covering the "lip"... should I remove that piece? Thanks. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062011.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1274062012.2.jpg) |
| r_towle |
May 17 2010, 09:03 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
looks stock.
If you look behind the headlights, inside and underneath you might see the LACK of seam sealer in there from the repair... Look at a stock car for comparison... That would most likely be a place they made an error. It looks like a clean, spot welded replacement panel. RIch |
poorsche914 Mounting area for both early and late bumpers? May 16 2010, 08:06 PM
jmill Leave the lip. You need it to hold in the hood se... May 16 2010, 08:20 PM
Root_Werks
Leave the lip. You need it to hold in the hood s... May 18 2010, 10:26 AM
70_914 That foglight mounting system is interesting. :c... May 16 2010, 09:47 PM
poorsche914 Yes, I noticed that too but the rains came and I d... May 16 2010, 10:32 PM
Dave_Darling I'm guessing the car was hit in the front, and... May 16 2010, 10:31 PM
Tom_T
http://www.914world.com/bbs2/uploads_offsite/www.... May 17 2010, 01:26 AM
dr914@autoatlanta.com The front panel HAS been replaced before. You MUST... May 17 2010, 08:43 AM
poorsche914
The front panel HAS been replaced before. You MUS... May 17 2010, 08:59 AM
r_towle Show a top and bottom pic of the serial number on ... May 17 2010, 08:50 AM
poorsche914
Show a top and bottom pic of the serial number on... May 17 2010, 09:00 AM
poorsche914
looks stock.
If you look behind the headlights, ... May 17 2010, 09:40 AM
jmill That's been hit and repaired. Here's pict... May 17 2010, 05:56 PM
poorsche914
That's been hit and repaired. ...
And upon ... May 17 2010, 06:38 PM
jmill
Looks like a relatively easy repair for someone w... May 17 2010, 06:02 PM
r_towle The seam sealer is the give away...in the first tw... May 17 2010, 06:36 PM
jmill
And upon further inspection, the driver quarter p... May 17 2010, 07:57 PM
poorsche914 I will take pics tomorrow. Passenger fender undern... May 17 2010, 09:40 PM
realred914 :sick: :trophy: :smash: :welder:
I will take p... May 18 2010, 09:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th September 2026 - 06:23 PM |
