I.D. My Tie Rod? |
I.D. My Tie Rod? |
kenshapiro2002 |
May 17 2010, 12:40 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Everywhere I look at parts the tie rods simply use a nut on the tie rod end threads to lock up against the tie rod itself. Mine are different...the tie rod is split at the outer end and there a pinch fitting to hold onto the tie rod end. Mine is a 1970. Are these stock tie rods for my car or something else?
TheCabinetmaker |
May 17 2010, 01:11 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
stock.
kenshapiro2002 |
May 17 2010, 01:19 PM
Spoke |
May 17 2010, 01:48 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So, are the stock ones split and the replacements not? Yes, yours are 70's stock. The replacement is later versions of 911 types. Identical in size but different in adjustment technique. If you replace yours, get turbo tierods from PP or AA or other reputable distributors. Not eBay. There are some cheap imitation turbo tierods out there. Lemforder is one of the good ones. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:08 AM |
