> Gear grind into 1st & R, Can high idle be the problem
EJP914
post May 15 2010, 04:35 PM
Is there any relationship between idle speed and gear grinding when going into 1st and Reverse? My car idles a little over 1000 rpm and it is now tough getting into 1st when stoppoing at intersection. Makes a hell of a racket.
It never did this before it was put away last yr.
Can this grinding be adjusted out by the clutch adjustment? Clutch pedal is pretty soft and mushy. It engages right off the floor.
How do you know if clutch tube is broken? Car shifts ok into 2-5 and back down.
Is this a synchro problem?
Sorry for alll the questions. Just trying to figure out what to look at first.
Figured someone out there has run into this already. Thanks
Dr Evil
post May 19 2010, 12:46 PM
Send me your transmission!
Yes, Terry is too long, but easily remedied by inserting a piece of tubing under the adjust nut.
post May 19 2010, 02:01 PM
QUOTE(Dr Evil @ May 19 2010, 11:46 AM) *
Dr.Evil,
Thats where they put about 10 washers still almost to floor,Should I get another cable,Is there a problem with terry cables,Thanks for the reply..
914
- Lo-Fi Version Time is now: 6th July 2026 - 11:00 AM
