DEAD WIPER MOTOR, wipers worked last fall but not now |
CHAZT54 |
May 20 2010, 11:32 AM
CHAZT54 Group: Members Posts: 19 Joined: 29-December 08 From: New London, Wisconsin Member No.: 9,878 Region Association: Upper MidWest |
I've got a '74 2.0 and am now getting it ready for fist show of the season. The windshieled wipers worked fine last fall when I parked it but don't now for some reason. I did restore the dash & instruments over the winter including cleaning up the heat/defrost controls, installing a push-button start switch (key switch was unreliable in crank position), and installed a MOMO wheel w/hub. The connections at the wiper motor, fuse block, and bottom of stalk switch are all solid. I get no power at the wiper motor connection with key on and wiper switch on. Could this be a dead spot in the wiper motor OR poor contacts in the stalk switch? I dread pulling those stalk switches from the column. Hoping for something simple. OTHER IDEAS? (IMG:style_emoticons/default/confused24.gif) CHARLIE |
detoxcowboy |
May 20 2010, 11:40 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
You will dread even more changing the wiper motor, been there done that .. best check everything else first.. no power at the wiper motor? then that is a better sigh than dead wiper motor.. keep tracin it back to the switch/ fuse block.. relay ect..
CHAZT54 |
May 20 2010, 12:23 PM
You will dread even more changing the wiper motor, been there done that .. best check everything else first.. no power at the wiper motor? then that is a better sigh than dead wiper motor.. keep tracin it back to the switch/ fuse block.. relay ect.. RELAY? I didn't know there was a relay involved with the wipers. Where do I find this puppy? |
Lo-Fi Version | Time is now: 6th June 2024 - 03:25 PM |
