DEAD WIPER MOTOR, wipers worked last fall but not now |
CHAZT54 |
May 20 2010, 11:32 AM
CHAZT54 Group: Members Posts: 19 Joined: 29-December 08 From: New London, Wisconsin Member No.: 9,878 Region Association: Upper MidWest |
I've got a '74 2.0 and am now getting it ready for fist show of the season. The windshieled wipers worked fine last fall when I parked it but don't now for some reason. I did restore the dash & instruments over the winter including cleaning up the heat/defrost controls, installing a push-button start switch (key switch was unreliable in crank position), and installed a MOMO wheel w/hub. The connections at the wiper motor, fuse block, and bottom of stalk switch are all solid. I get no power at the wiper motor connection with key on and wiper switch on. Could this be a dead spot in the wiper motor OR poor contacts in the stalk switch? I dread pulling those stalk switches from the column. Hoping for something simple. OTHER IDEAS? (IMG:style_emoticons/default/confused24.gif) CHARLIE |
eitnurg |
May 20 2010, 12:35 PM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
Pulling the stalk switch is no drama at all. Only confusing part is (ISTR) that wiring colours within the switch differ from the corresponding connections in the multi-pin plug (& which the wiring diagram refers to).
It may be that wiper spindles have siezed from non-use, and switching them on has melted the plastic contact holders in the stalk switch so that the contacts no longer contact. Means "new switch". Don't ask me how I know. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:57 AM |
