| mipstien |
May 21 2010, 09:04 PM
Member ![]() ![]() Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
im trying to see what i have and don't have in my engine bay and why i seem to have missing vacuum hoses.
can i get a few pictures of peoples engine bays. possibly one with smog equipment and one without. and what is an anti flash back valve? |
| mipstien |
May 21 2010, 09:47 PM
75 2l djet. i can get pictures but im missing the evaporative filter and anti flash back pieces. and also when i was out checking out the vacuum lines we created suction on both sides of the distributor and it caused it to idle a lot smoother. although not perfect.
ill try and get pictures in a couple of minutes |
mipstien engine pictures May 21 2010, 09:04 PM
avidfanjpl What model or engine number do you have in there? ... May 21 2010, 09:34 PM
mipstien http://www.914world.com/bbs2/index.php?sho...c=972... May 21 2010, 09:48 PM
mipstien hoses that are disconnected are to the air filter,... May 21 2010, 09:58 PM
mipstien disregard that yellow hose there it is just an ext... May 21 2010, 10:00 PM
avidfanjpl Ok. I see some things.
The PCV Valve is the OEL c... May 21 2010, 10:31 PM
mipstien i have the aux air valve with both of its plugs in... May 21 2010, 10:40 PM
mipstien :confused::confused::confused::confused::confused:... May 22 2010, 08:03 AM
mipstien so i got to messing with this again today. i remov... May 22 2010, 04:42 PM
detoxcowboy
so i got to messing with this again today. i remo... May 23 2010, 11:39 AM
mipstien aar valve shows the correct ohms and it seems to b... May 22 2010, 10:22 PM
Tom You can look in the originality and history sectio... May 23 2010, 11:08 AM
underthetire If you haven't found this yet http://members.... May 23 2010, 11:19 AM
SirAndy A little cleaning wouldn't hurt either ...
... May 23 2010, 11:54 AM
mipstien im confused as to why you folks won't answer m... May 23 2010, 11:55 AM
underthetire
im confused as to why you folks won't answer ... May 23 2010, 12:10 PM
mipstien and im sorry im frustrated and really don't li... May 23 2010, 12:04 PM
BigDBass Hi,
Can't offer up any how or why, but can off... May 23 2010, 12:06 PM
mipstien
Hi,
Can't offer up any how or why, but can of... May 23 2010, 12:13 PM
mipstien
im confused as to why you folks won't answer... May 23 2010, 12:15 PM
Tom Did you look at the engine bay pictures on the ori... May 23 2010, 03:27 PM
underthetire If you have normal idle with the aar open and pull... May 23 2010, 04:18 PM
mipstien i have a head temp sensor on its way and that was ... May 23 2010, 04:39 PM
mipstien i have been reading a little more on
http://membe... May 23 2010, 08:04 PM
detoxcowboy
http://memb... May 24 2010, 05:58 PM
mipstien weirdest thing just happened.
earlier we regaped t... May 23 2010, 08:11 PM
detoxcowboy
earlier we regaped ... May 24 2010, 05:45 PM
mipstien so im starting to talk to myself.
anyways
after a... May 24 2010, 04:57 PM
detoxcowboy
anyways
after ... May 24 2010, 05:51 PM
mipstien
earlier we regaped... May 24 2010, 05:48 PM
if so when i put it back on this evening it shoul... May 24 2010, 05:58 PM
detoxcowboy
if so when i put it back on this evening it shou... May 24 2010, 06:06 PM
mipstien
anyways
after... May 24 2010, 05:53 PM
mipstien is the wire that goes that thing red or white? any... May 24 2010, 05:55 PM
mipstien I'm only asking questions I n theory. I want t... May 24 2010, 06:15 PM
mipstien i know you said im chasing my tail but as of today... May 25 2010, 01:36 PM
mipstien did some more testing and playing around yesterday... May 26 2010, 05:25 AM
type47
.... when i plug the leak it runs good or rather... May 26 2010, 09:17 AM
mipstien The mps isn't bad but it has been tampered wit... May 26 2010, 11:24 AM
mipstien The leak was with the hose not the mps itself May 26 2010, 11:26 AM
mtndawg I picked up a 1.7L d-jet a year and a half ago and... May 26 2010, 01:03 PM
mipstien for one the forum user that owned the car before m... May 26 2010, 02:29 PM
mipstien which direction does the AAR valve go. top hose on... May 30 2010, 05:07 PM
detoxcowboy
which direction does the AAR valve go. top hose o... May 30 2010, 05:17 PM
mipstien well take this for example
http://www.914world.com... May 30 2010, 05:45 PM
mipstien ok i think i found 'stock' pictures so ill... May 30 2010, 05:49 PM
mipstien with the mps unattached the car runs a little stra... May 30 2010, 06:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 04:32 AM |
