kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
Replacing the ball joint on my early style (split end) 911 strut. The PO simply (and wrongly) put a "regular" bolt all the way through the BJ retaining hole with a nut on the end. As I now insect the threads on one side of the hole, they look rusty and may just be gone. My first impulse is to "chase" the threads and see if they are still there...still usable. Should I first soak them with something like PB Blaster? Then, should I use a correctly threaded bolt to "chase " the threads or use something else?
If the treads are gone, can I use a helicoil in that area, and can it be done with the strut on the car? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Use a tap to chase the threads .... period! A helicoil or timecert wouldn't hurt but it has to be drilled straight. Timecert is the strongest.
A longer fastener with a nut on the outside is not the worst idea I've heard. I don't have any early 911 3" spacing struts. |
kenshapiro2002 |
Thanks. You think there's any way to drill "straight" using hand tools on a strut still hanging on the car?
Use a tap to chase the threads .... period! A helicoil or timecert wouldn't hurt but it has to be drilled straight. Timecert is the strongest. A longer fastener with a nut on the outside is not the worst idea I've heard. I don't have any early 911 3" spacing struts. |
Lo-Fi Version | Time is now: 4th July 2025 - 01:37 PM |
