> engine pictures
mipstien
post May 21 2010, 09:04 PM
im trying to see what i have and don't have in my engine bay and why i seem to have missing vacuum hoses.
can i get a few pictures of peoples engine bays. possibly one with smog equipment and one without. and what is an anti flash back valve?
Tom
post May 23 2010, 11:08 AM
You can look in the originality and history section for a lot of engine bay pics. Just remember that they will be stock.
Looking at your pictures I see a lot of rust. Have you checked out the longs and hell hole?
You may be better off droping the engine/trans and cleaning everything up good and rewiring/rehosing with the engine out of the bay. So much easier to work on. Then when you have it all sorted, it shouldn't be too much trouble to get the idle straightened out. This is what I did to mine as it wasn't running very well when I first got it. I found and repaired a lot of bad wires and connections, but when I pulled the tin I got my biggest surprise. Lots of "stuff" up under the tins blocking cooling air.
With everything I found repaired and the engine back in, it ran great. So those bad wires and connections really made a difference. Plus it looks really nice now and clean too.
While the engine is out, you can better address the rust issues.
Good luck,
Tom
mipstien   engine pictures   May 21 2010, 09:04 PM
avidfanjpl   What model or engine number do you have in there? ...   May 21 2010, 09:34 PM
mipstien   75 2l djet. i can get pictures but im missing the ...   May 21 2010, 09:47 PM
mipstien   http://www.914world.com/bbs2/index.php?sho...c=972...   May 21 2010, 09:48 PM
mipstien   hoses that are disconnected are to the air filter,...   May 21 2010, 09:58 PM
mipstien   disregard that yellow hose there it is just an ext...   May 21 2010, 10:00 PM
avidfanjpl   Ok. I see some things. The PCV Valve is the OEL c...   May 21 2010, 10:31 PM
mipstien   i have the aux air valve with both of its plugs in...   May 21 2010, 10:40 PM
mipstien   :confused::confused::confused::confused::confused:...   May 22 2010, 08:03 AM
mipstien   so i got to messing with this again today. i remov...   May 22 2010, 04:42 PM
detoxcowboy   so i got to messing with this again today. i remo...   May 23 2010, 11:39 AM
mipstien   aar valve shows the correct ohms and it seems to b...   May 22 2010, 10:22 PM
Tom   You can look in the originality and history sectio...   May 23 2010, 11:08 AM
underthetire   If you haven't found this yet http://members....   May 23 2010, 11:19 AM
SirAndy   A little cleaning wouldn't hurt either ... ...   May 23 2010, 11:54 AM
mipstien   im confused as to why you folks won't answer m...   May 23 2010, 11:55 AM
underthetire   im confused as to why you folks won't answer ...   May 23 2010, 12:10 PM
mipstien   and im sorry im frustrated and really don't li...   May 23 2010, 12:04 PM
BigDBass   Hi, Can't offer up any how or why, but can off...   May 23 2010, 12:06 PM
mipstien   Hi, Can't offer up any how or why, but can of...   May 23 2010, 12:13 PM
mipstien   im confused as to why you folks won't answer...   May 23 2010, 12:15 PM
Tom   Did you look at the engine bay pictures on the ori...   May 23 2010, 03:27 PM
underthetire   If you have normal idle with the aar open and pull...   May 23 2010, 04:18 PM
mipstien   i have a head temp sensor on its way and that was ...   May 23 2010, 04:39 PM
mipstien   i have been reading a little more on http://membe...   May 23 2010, 08:04 PM
detoxcowboy   i have been reading a little more on http://memb...   May 24 2010, 05:58 PM
mipstien   weirdest thing just happened. earlier we regaped t...   May 23 2010, 08:11 PM
detoxcowboy   weirdest thing just happened. earlier we regaped ...   May 24 2010, 05:45 PM
mipstien   so im starting to talk to myself. anyways after a...   May 24 2010, 04:57 PM
detoxcowboy   so im starting to talk to myself. anyways after ...   May 24 2010, 05:51 PM
mipstien   weirdest thing just happened. earlier we regaped...   May 24 2010, 05:48 PM
SirAndy   if so when i put it back on this evening it shoul...   May 24 2010, 05:58 PM
detoxcowboy   if so when i put it back on this evening it shou...   May 24 2010, 06:06 PM
mipstien   so im starting to talk to myself. anyways after...   May 24 2010, 05:53 PM
mipstien   is the wire that goes that thing red or white? any...   May 24 2010, 05:55 PM
mipstien   I'm only asking questions I n theory. I want t...   May 24 2010, 06:15 PM
mipstien   i know you said im chasing my tail but as of today...   May 25 2010, 01:36 PM
mipstien   did some more testing and playing around yesterday...   May 26 2010, 05:25 AM
type47   .... when i plug the leak it runs good or rather...   May 26 2010, 09:17 AM
mipstien   The mps isn't bad but it has been tampered wit...   May 26 2010, 11:24 AM
mipstien   The leak was with the hose not the mps itself   May 26 2010, 11:26 AM
mtndawg   I picked up a 1.7L d-jet a year and a half ago and...   May 26 2010, 01:03 PM
mipstien   for one the forum user that owned the car before m...   May 26 2010, 02:29 PM
mipstien   which direction does the AAR valve go. top hose on...   May 30 2010, 05:07 PM
detoxcowboy   which direction does the AAR valve go. top hose o...   May 30 2010, 05:17 PM
mipstien   well take this for example http://www.914world.com...   May 30 2010, 05:45 PM
mipstien   ok i think i found 'stock' pictures so ill...   May 30 2010, 05:49 PM
mipstien   with the mps unattached the car runs a little stra...   May 30 2010, 06:30 PM
- Lo-Fi Version Time is now: 5th March 2026 - 03:06 AM
