Almost had it running but not getting fuel |
Geezer914 |
May 23 2010, 07:06 PM
Geezer914 Group: Members Posts: 1,443 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
1975 1.8L with original fuel injection. I have totally gone over the car during the past year, replacing everything that needed replacing. I pulled the engine to repair some rust along the bottom of the engine compartment. I replaced the old plastic lines with new stainless lines in the tunnel, all new rubber fuel hoses, and filter, the PO had just installed a new fuel pump just before I bought the car. I drove it home and it ran fine. It starts with a blast of starting fluid, runs for a few seconds and dies. I can hear the fuel pump turn on and stop when I turn the key. I loosened the outlet line on the fuel pump and there was gas. I removed the fuel hose from the U shaped tube going to the injectors and there was no gas. Just to be shure I did not switch the inlet line with the return line, I used a Mighty Vac and was able to suck gas out of the line.
It seems the pump is not pumping when the car is starting, I should have had gas at the inlet line in the engine (IMG:style_emoticons/default/confused24.gif) compartment??? How many turns out for the idle adjustment screw in the throttle body??? Help! It is finally off the jack stands and I want to get this car on the road! (IMG:style_emoticons/default/confused24.gif) |
avidfanjpl |
May 23 2010, 07:43 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Not that familiar with the 1.8, but my buds have had airbox problems which gave them headaches because the fuel pump runs off the airbox, being a hinged door that has a sweeping contact point that must be functional.
This is peculiar to the L Jetronic, but someone help the man out here! John |
Lo-Fi Version | Time is now: 8th June 2024 - 01:08 AM |
