MSD billit distrib problem, no wonder it rus like sh**t |
fitzm1 |
May 24 2010, 11:29 AM
Member Group: Members Posts: 74 Joined: 21-April 08 From: Ballston lake,ny Member No.: 8,947 Region Association: None |
McMark |
May 25 2010, 11:25 AM
Mounting the vent box higher is not a requirement. If you don't and if you have a lot of oil vapor collecting in the box, you can find that it will fill up the box. So if it's lower, just keep an eye on it.
Also, if you do mount the box higher you should think about removing the valve from the PCV system. The valve will keep oil from draining back to the crankcase anyway, and if you fill that line with oil, it could keep the valve from opening and then you have NO crankcase ventilation which IS bad. (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:11 AM |
