| theo |
May 25 2010, 03:32 PM
Newbie ![]() Group: Members Posts: 26 Joined: 4-December 07 From: Vancouver WA Member No.: 8,417 |
does anyone have some pictures of how they have mounted the fuel pump (for carbs) in the front trunk after relocating? thanks
Theo |
| Tom_T |
May 25 2010, 07:07 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
On my 73 2L it was relocated up behind the steering rack & protected by the rack pan in 1977 per Porsche's reccos, by my factory trained independent 914 mechanic. This was preferable to locating under the fuel tank, because the pre-75 didn't have the access hatch/opening in the front trunk bulkhead to get at it if something went wrong.
However, it still ties in easily with the OE fuel lines from the tank to the tunnel, although they wired the new electrical under the passenger side rocker panel (no tubing unless AC), then along the floor pan seam, to under the steering rack cover pan. I'll relocate it to the tunnel in my shell/frame up resto though, along with new SS fuel lines (you should also consider the latter from Tangerine Racing - a vendor on here). Mine is still the D-jet, but carbs or EFI - you'll want the fuel pump accessible & the steering rack cover is a heck of alot easier to remove than the fuel tank. AA sells a complete kit & instructions for FP relo, but I don't know where they recco putting it, although I assume the kit works for the steering rack well/inset location in any case. BTW - they have the rubber isolators that Murray/me733 is talking about above. I think that someone here probably has the Porsche Service Bulletin for the 70-74 fuel pump relocation that maybe they could post the pages for you. Maybe Jeff Bowlsby?? (IMG:style_emoticons/default/confused24.gif) Here's a pic of mine (yup - dirty after DD use 75-85 & in my garage 85-now), & th lines are accessed thru the factory hole for the fuel filter changes in 2nd pic - Hope this helps! (IMG:style_emoticons/default/popcorn[1].gif) |
theo Mounting fuel pump May 25 2010, 03:32 PM
RobW I don't have pictures but I stuck mine foward ... May 25 2010, 03:37 PM
ME733 ....Mounting fuel pump, sorry no pictures...mounti... May 25 2010, 03:49 PM
jt914-6 I don't have any pic either. I'm using a f... May 25 2010, 03:52 PM
detoxcowboy :DRUNK: no pics but mine is mounted like tom t. on... May 25 2010, 08:10 PM
Jeffs9146 Uhhhhhh do you see a problem in this photo? :blink... May 25 2010, 10:51 PM
jcb29 Don't know which applies but here are two page... May 26 2010, 12:48 PM
underthetire
Uhhhhhh do you see a problem in this photo? :blin... May 26 2010, 12:57 PM
Uhhhhhh do you see a problem in this photo? :blin... May 26 2010, 05:57 PM
Nie Zu Alt Even though it's a pump for F.I., this is how ... May 26 2010, 05:53 PM
Even though it's a pump for F.I., this is how... May 26 2010, 05:59 PM
Nie Zu Alt Thanks Andy, I should know better. Hmmm, looks lik... May 26 2010, 06:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 03:42 AM |
