| theo |
May 25 2010, 03:32 PM
Newbie ![]() Group: Members Posts: 26 Joined: 4-December 07 From: Vancouver WA Member No.: 8,417 |
does anyone have some pictures of how they have mounted the fuel pump (for carbs) in the front trunk after relocating? thanks
Theo |
| detoxcowboy |
May 25 2010, 08:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/drunk.gif) no pics but mine is mounted like tom t. on isolators under the fuel tank by the steerin rack accesible from the skid plate 8 inches from the master cylinder ect.. but i have it wired coming through the wall behind the pedal cluster and through the tunnel out the rear fire wall up to the old wiring.. nothing is straped to the fuel lines under the tank.. and the filter is line from the tank feed to the pump then is is only 6 inches of hose connection to the feed and return lines right there in the opening under tank.. simple and not alot of fuel lines andf electrical rtunning around your spare tire ect..
theo Mounting fuel pump May 25 2010, 03:32 PM
RobW I don't have pictures but I stuck mine foward ... May 25 2010, 03:37 PM
ME733 ....Mounting fuel pump, sorry no pictures...mounti... May 25 2010, 03:49 PM
jt914-6 I don't have any pic either. I'm using a f... May 25 2010, 03:52 PM
Tom_T On my 73 2L it was relocated up behind the steerin... May 25 2010, 07:07 PM
Jeffs9146 Uhhhhhh do you see a problem in this photo? :blink... May 25 2010, 10:51 PM
jcb29 Don't know which applies but here are two page... May 26 2010, 12:48 PM
underthetire
Uhhhhhh do you see a problem in this photo? :blin... May 26 2010, 12:57 PM
Uhhhhhh do you see a problem in this photo? :blin... May 26 2010, 05:57 PM
Nie Zu Alt Even though it's a pump for F.I., this is how ... May 26 2010, 05:53 PM
Even though it's a pump for F.I., this is how... May 26 2010, 05:59 PM
Nie Zu Alt Thanks Andy, I should know better. Hmmm, looks lik... May 26 2010, 06:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 03:42 AM |
