| JRust |
May 25 2010, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Okay so I am putting a nice set of dual weber 40's on the LE. Going to get my break in miles done & drive it while I work on the FI stuff on the side. I get the basics of how to get them on. Was hoping someone could give me a nice step by step so I don't miss anything. Or put it on in the wrong order. I got the complete setup from Rich & he included everything needed except linkage which I picked up.
I allready installed the distributor & the intakes. I know I need to get my car to TDC & make sure my firing order is right. Okay lay it on me (IMG:style_emoticons/default/biggrin.gif) . In simple terms please (IMG:style_emoticons/default/blink.gif) |
| type2man |
May 25 2010, 05:49 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Bolting them on is pretty straight forward. The important part would be figuring out how much accelerator cable length you have and where it will be mounted and then you can work the linkage around it. Post up some pics of your carbs and the linkage, and I can help you out...
| JRust |
May 25 2010, 07:33 PM
Bolting them on is pretty straight forward. The important part would be figuring out how much accelerator cable length you have and where it will be mounted and then you can work the linkage around it. Post up some pics of your carbs and the linkage, and I can help you out... Here are pics Attached image(s)
| SirAndy |
May 25 2010, 09:47 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,559 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here are pics That fuel pump is going to drive you nuts ... (IMG:style_emoticons/default/shades.gif) Andy |
JRust Installing dual carbs for the first time May 25 2010, 05:29 PM
JRust
Here are pics
That fuel pump is going to drive y... May 25 2010, 09:58 PM
jmill Buy the weber tech manual. It's worth the mon... May 25 2010, 06:53 PM
Kirmizi Get a rotary, Carter IIRC, but I can't remembe... May 25 2010, 11:38 PM
KaptKaos http://www.cbperformance.com/catalog.asp?ProductID... May 26 2010, 12:38 AM
Cevan Even if those are new carbs, they could probably u... May 26 2010, 05:20 AM
Gint You'd be a lot better off just getting the FI ... May 26 2010, 05:47 AM
dr914@autoatlanta.com Don't do it and ruin this "special" ... May 26 2010, 07:54 AM
tomeric914 Tech manual:
http://www.cbperformance.com/catalog... May 26 2010, 08:33 AM
computers4kids Jamie,
Seems like you should be able to buy a comp... May 26 2010, 08:58 AM
sean_v8_914 call me or PM. I'll try to help with your FI May 26 2010, 09:39 AM
sean_v8_914 dfghrehtr May 26 2010, 09:41 AM
sean_v8_914 fxhfdth May 26 2010, 09:42 AM
sean_v8_914 chfdzghd May 26 2010, 09:42 AM
sean_v8_914 bvngfxnfg May 26 2010, 09:43 AM
sean_v8_914 gcnbgfn May 26 2010, 09:44 AM
sean_v8_914 gfngfdn May 26 2010, 09:44 AM
sean_v8_914 fdhfdh May 26 2010, 09:45 AM
sean_v8_914 fghjftrjtrj May 26 2010, 09:46 AM
sean_v8_914 this linkage set up is also common but not my favo... May 26 2010, 09:50 AM
sean_v8_914 dfrgfdgfd May 26 2010, 09:53 AM
McMark Sean, those drawings were you try to equalize ever... May 26 2010, 10:34 AM
Vacca Rabite :agree: I tried to draw it out the first time, an... May 26 2010, 11:11 AM
rhodyguy jamie, if you did not install the phenolic intake ... May 26 2010, 02:00 PM
JRust Okay thanks for all the tips! I am holding off... May 26 2010, 02:49 PM
Okay thanks for all the tips! I am holding of... May 26 2010, 02:54 PM
McMark I'm extremely anxious to see what it was that ... May 26 2010, 02:53 PM
Dr Evil
I'm extremely anxious to see what it was that... May 26 2010, 03:07 PM
JRust
I'm extremely anxious to see what it was tha... May 26 2010, 07:57 PM
Rav914 Save the carbs. IF you get tired of spending week... May 26 2010, 03:03 PM
Lennies914 :popcorn: I have to admit, I was a little bummed t... May 26 2010, 08:04 PM
JRust Going with Carbs was always & only going to be... May 26 2010, 08:24 PM
Root_Werks Be very interesting to see what makes the FI work.... May 27 2010, 01:33 PM
Shade Tree Well, hopefully, Bruce will see this post. He lik... May 27 2010, 02:02 PM
sean_v8_914 not the measurements, just teh angles. its relativ... May 27 2010, 03:19 PM
Root_Werks These are good linkage pictures, what kind of link... May 27 2010, 03:44 PM
Root_Werks More of it, it's on my engine, haven't see... May 27 2010, 03:46 PM
computers4kids
More of it, it's on my engine, haven't se... May 29 2010, 09:17 AM
Root_Werks
More of it, it's on my engine, haven't s... May 29 2010, 11:34 AM
biosurfer1 looks similar to the one I just setup and I agree,... May 27 2010, 03:53 PM
Root_Werks
looks similar to the one I just setup and I agree... May 28 2010, 09:18 AM
sean_v8_914 shzfdg May 28 2010, 09:46 AM
Racer Chris
shzfdg
It just so happens that I have a special ... May 28 2010, 12:11 PM
gothspeed To the OP ......... I will take those horribel car... May 28 2010, 12:00 PM
biosurfer1 Sean...can you take a picture of your return sprin... May 28 2010, 12:17 PM
arkitect Jrust,
What size carbs, just wondering for my proj... May 29 2010, 06:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 12:54 AM |
