| JRust |
May 25 2010, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Okay so I am putting a nice set of dual weber 40's on the LE. Going to get my break in miles done & drive it while I work on the FI stuff on the side. I get the basics of how to get them on. Was hoping someone could give me a nice step by step so I don't miss anything. Or put it on in the wrong order. I got the complete setup from Rich & he included everything needed except linkage which I picked up.
I allready installed the distributor & the intakes. I know I need to get my car to TDC & make sure my firing order is right. Okay lay it on me (IMG:style_emoticons/default/biggrin.gif) . In simple terms please (IMG:style_emoticons/default/blink.gif) |
| tomeric914 |
May 26 2010, 08:33 AM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,325 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Tech manual:
http://www.cbperformance.com/catalog.asp?ProductID=4 You'll need a synchrometer as well: http://www.cbperformance.com/catalog.asp?ProductID=572 or http://www.pegasusautoracing.com/productde...s.asp?RecID=826 Prepare to become a meticulous expert in Webers if you want them to run right. Float setting is critical because it affects the transition between jets. Jetting is done via seat of your pants. What works on one motor may not work on your motor. Idle jets function at more than just idle. Transition to mains is at about 2500-3000 and to air correction jets at 4500-5000 with F11 emulsion tubes CLEAN EVERYTHING. Even new carbs need to be cleaned. All it takes is one little chunk to come loose and get stuck in one of the many jets. If you don't have the rain tray on your engine lid installed, make sure to have rain hats over the air filters. Water can get in through the top of the carbs if not sealed up. Rainwater is bad enough. Depending on what you use to wash your car, soapy water is bad news inside a Weber. I prefer the CBPerformance hex bar setup that integrates the pivot point into the air filter base (PN 3413 and 3414). Makes for a clean installation and no possibility for air to bypass the filter or water to get into the carb. http://www.cbperformance.com/catalog.asp?ProductID=547 Make sure the intakes are 100% sealed. Vacuum leaks are not your friend. Invest in earplugs for DE's. WOT is loud, even through a helmet. If you understand how Webers work, you'll enjoy them. If not, you won't. I have 2 cars with dual IDFs on them, one of which I have had Webers on for close to 15 years now. |
JRust Installing dual carbs for the first time May 25 2010, 05:29 PM
type2man Bolting them on is pretty straight forward. The im... May 25 2010, 05:49 PM
JRust
Bolting them on is pretty straight forward. The i... May 25 2010, 07:33 PM
Here are pics
That fuel pump is going to drive yo... May 25 2010, 09:47 PM
JRust
Here are pics
That fuel pump is going to drive y... May 25 2010, 09:58 PM
jmill Buy the weber tech manual. It's worth the mon... May 25 2010, 06:53 PM
Kirmizi Get a rotary, Carter IIRC, but I can't remembe... May 25 2010, 11:38 PM
KaptKaos http://www.cbperformance.com/catalog.asp?ProductID... May 26 2010, 12:38 AM
Cevan Even if those are new carbs, they could probably u... May 26 2010, 05:20 AM
Gint You'd be a lot better off just getting the FI ... May 26 2010, 05:47 AM
dr914@autoatlanta.com Don't do it and ruin this "special" ... May 26 2010, 07:54 AM
computers4kids Jamie,
Seems like you should be able to buy a comp... May 26 2010, 08:58 AM
sean_v8_914 call me or PM. I'll try to help with your FI May 26 2010, 09:39 AM
sean_v8_914 dfghrehtr May 26 2010, 09:41 AM
sean_v8_914 fxhfdth May 26 2010, 09:42 AM
sean_v8_914 chfdzghd May 26 2010, 09:42 AM
sean_v8_914 bvngfxnfg May 26 2010, 09:43 AM
sean_v8_914 gcnbgfn May 26 2010, 09:44 AM
sean_v8_914 gfngfdn May 26 2010, 09:44 AM
sean_v8_914 fdhfdh May 26 2010, 09:45 AM
sean_v8_914 fghjftrjtrj May 26 2010, 09:46 AM
sean_v8_914 this linkage set up is also common but not my favo... May 26 2010, 09:50 AM
sean_v8_914 dfrgfdgfd May 26 2010, 09:53 AM
McMark Sean, those drawings were you try to equalize ever... May 26 2010, 10:34 AM
Vacca Rabite :agree: I tried to draw it out the first time, an... May 26 2010, 11:11 AM
rhodyguy jamie, if you did not install the phenolic intake ... May 26 2010, 02:00 PM
JRust Okay thanks for all the tips! I am holding off... May 26 2010, 02:49 PM
Okay thanks for all the tips! I am holding of... May 26 2010, 02:54 PM
McMark I'm extremely anxious to see what it was that ... May 26 2010, 02:53 PM
Dr Evil
I'm extremely anxious to see what it was that... May 26 2010, 03:07 PM
JRust
I'm extremely anxious to see what it was tha... May 26 2010, 07:57 PM
Rav914 Save the carbs. IF you get tired of spending week... May 26 2010, 03:03 PM
Lennies914 :popcorn: I have to admit, I was a little bummed t... May 26 2010, 08:04 PM
JRust Going with Carbs was always & only going to be... May 26 2010, 08:24 PM
Root_Werks Be very interesting to see what makes the FI work.... May 27 2010, 01:33 PM
Shade Tree Well, hopefully, Bruce will see this post. He lik... May 27 2010, 02:02 PM
sean_v8_914 not the measurements, just teh angles. its relativ... May 27 2010, 03:19 PM
Root_Werks These are good linkage pictures, what kind of link... May 27 2010, 03:44 PM
Root_Werks More of it, it's on my engine, haven't see... May 27 2010, 03:46 PM
computers4kids
More of it, it's on my engine, haven't se... May 29 2010, 09:17 AM
Root_Werks
More of it, it's on my engine, haven't s... May 29 2010, 11:34 AM
biosurfer1 looks similar to the one I just setup and I agree,... May 27 2010, 03:53 PM
Root_Werks
looks similar to the one I just setup and I agree... May 28 2010, 09:18 AM
sean_v8_914 shzfdg May 28 2010, 09:46 AM
Racer Chris
shzfdg
It just so happens that I have a special ... May 28 2010, 12:11 PM
gothspeed To the OP ......... I will take those horribel car... May 28 2010, 12:00 PM
biosurfer1 Sean...can you take a picture of your return sprin... May 28 2010, 12:17 PM
arkitect Jrust,
What size carbs, just wondering for my proj... May 29 2010, 06:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 11:55 PM |
