jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Can you use a DA to cut and buff clear coat with the proper bonnet/pad?
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Yes. Pads are available to polish with the DA set to circular. Most guys only use it for small spots, it's way too slow and not enough power and it's more likely to burn through because you have less control without a side handle. 1500g 2000g even 3000g sandpaper is available for the DA to colorsand. Don't bother, it does more harm than good. Just wet sand it like everyone else.
jeffdon |
Yes. Pads are available to polish with the DA set to circular. Most guys only use it for small spots, it's way too slow and not enough power and it's more likely to burn through because you have less control without a side handle. 1500g 2000g even 3000g sandpaper is available for the DA to colorsand. Don't bother, it does more harm than good. Just wet sand it like everyone else. I was thinking more about the buffing than the wet sanding. Actually, I rather like wet sanding by hand in the final stages. something about it is very satisfying. |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:13 PM |
